Author Topic: Ambient AQIN Calibration and GW1100  (Read 292 times)
Offline kheller2
« on: January 09, 2022, 07:50:24 PM »
Where does one adjust the calibration of the AQIN in the GW1100 web interface?  Under C02 Calibration you can adjust CO2, PM2.5 and PM10 but not temp and humidity... Is this by design?
Ambient Consoles: WS-2000, WS-1900, WS-1200, WS-2902C, WS-3000-X3, WS-0900-IP(observerIP), WS-1001-WIFI
Ambient Arrays: WH65B
Ambient Sensors: WH31E(3), WH31B(2), WH32B, WH31SM(2), WH31PGW, AQIN, WH31LA(3)
Ambient Spares: WH24B(2), WH25B.
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Gyvate
Re: Ambient AQIN Calibration and GW1100
« Reply #1 on: January 09, 2022, 08:03:03 PM »
Looks like by design - you can't calibrate the WH45 T/H values from the HP2551 console either. Nor from a GW1000/WH2650 in WS View.
Or, in Ambient terms, you can't calibrate the AQIN T/H values from the WS-2000/5000 console either.
I have created a suggestion for a future firmware upgrade in the ecowitt.com forum (not yet visible as still under review by Ecowitt).
EDIT: meanwhile released
« Last Edit: January 11, 2022, 01:50:16 PM by Gyvate »
Offline kheller2
« Reply #2 on: January 11, 2022, 11:41:53 AM »
Thank you for that suggestion.  I noticed that I couldn't calibrate it on the WS-2000 either.  Mine is off about 4-5% on the humidity level, which is rather odd.  BTW, how often is the fan supposed to spin up on this? I know its at least every 60 seconds, but I feel its 30 sometimes.
