Author Topic: 2 x GW1100 with WS80: GW1100/WS90 sensor firmware issue  (Read 646 times)
Offline Gyvate
« on: January 08, 2022, 04:32:29 AM »
if you are running two GW1100 with one WS80 (ultrasonic 6-in-1 array), there is a GW1100 firmware issue aknowledged by Ecowitt which may lead to one of the GW1100 starting reporting bogus readings.
One of our forum members from NL went down this path.
The workaround is to make sure, by the help of the WS View Plus (!) app, to actively disable the WS90 sensor ID entry in th SensorsID section. Don't let it run in "learning" mode.
see also https://www.wxforum.net/index.php?topic=43205.msg440146#msg440146
« Last Edit: January 08, 2022, 04:42:32 AM by Gyvate »
Offline Gyvate
Re: 2 x GW1100 with WS80: GW1100/WS90 sensor firmware issue
« Reply #1 on: January 08, 2022, 04:45:34 AM »
It's in general good practice to disable actively all sensors that you do not have/don't use with your specific console.
This also helps reducing the sequence problems with multi-channel sensors like WH31 family, WH51, WH55, WN34/35 in cse of reboots.
Offline HansR
    • De Wilgen
« Reply #2 on: January 08, 2022, 05:12:06 AM »
OK.
Would appreciate if you stick to one thread so all who reply there get this info (I replied myself there)
Offline broadstairs
« Reply #3 on: January 08, 2022, 06:12:27 AM »
I now find that having disabled all sensors I do not have on my GW1100 that I do have a WH25 showing up on the battery data I extract, there is no WH25 showing up on the sensor IDs page. I have everything disabled which is not actually available!
I am finding this f/w for the GW1100 very flaky, why on earth would the WH25 show up when it does not exist?
Stuart
Offline HansR
    • De Wilgen
« Reply #4 on: January 08, 2022, 06:19:20 AM »
@broadstairs: Well, that is interesting because it shows that a similar error can occur outside the WS80 issue with another device (What is a WH25?). I'll bring that back in my comms with Ecowitt. Indeed the firmware seems to have an issue  :roll:
Offline olicat
    • FOSHKplugin
« Reply #5 on: January 08, 2022, 06:24:08 AM »
Hi!
What is a WH25?
The WH25 is probably a WH32B T/H/P sensor for the HP2551C/HP3501 or WH26x0.
Stuart, do you own such a device?
Oliver
Offline broadstairs
« Reply #6 on: January 08, 2022, 06:31:32 AM »
Hi!
Oliver
No I do not have any of those only a GW1100 which shows this battery data:-
Sensor WH80 Sensor ID 000b0029 Battery Status 2.94 Volts Signal Status 04
Sensor WH40 Sensor ID 0000c4a6 Battery Status 1.6 Volts Signal Status 04
Sensor WH25 offline
Sensor WH31 CH1 Sensor ID 0000009e Battery Status Normal Signal Status 04
Sensor WH31 CH2 Sensor ID 000000d9 Battery Status Normal Signal Status 04
Sensor WH41 CH1 Sensor ID 000000a8 Battery Status 3 Signal Status 04
Sensor WH57 Sensor ID 0000f73e Battery Status 5 Signal Status 04
and a GW1000 which does not show the WH25, both are on the latest f/w.
Stuart
Offline davidefa
« Reply #7 on: January 08, 2022, 07:09:40 AM »
Hi!
What is a WH25?
Oliver
Yes it is, I have a wh2650 with this T/H/P sensor and it reports as wh25batt ( I think simply for compatibility with older versions )
Only a note: also the ws65 reports its rf data with the '24' type code ( as if it where a wh24 ), but sensors have has different conversion factors ( think for compatibility too )
Offline HansR
    • De Wilgen
« Reply #8 on: January 08, 2022, 07:50:45 AM »
@broadstairs: switch that WH25 off in WSview plus anyway!
(I had to do it in two steps as well as I had to disable a complete station (see screenshot) which I did not have but suddenly became active. Also the WH32 suddenly remained enabled and could only be disabled after disabling the aforementioned station).
Offline broadstairs
« Reply #9 on: January 08, 2022, 08:22:49 AM »
The point is it ONLY shows in battery data, it is NOT listed in sensor IDs. As I said I have all non-existent sensors disabled but as this does not show I cannot disable it!
Stuart
Offline davidefa
« Reply #10 on: January 08, 2022, 09:30:26 AM »
Sensor WH25 offline
Stuart
Are you using the gw1100 api to retrieve these battery data ( if so could you share the program you use )?
Did you power cycle the gw1100 ( maybe the variable was created and not deleted after you removed the sensor )?
Otherwise it could be a 'youth' bug of the gw1100 ( as you could already have imagined ).
Offline broadstairs
« Reply #11 on: January 08, 2022, 10:01:20 AM »
I had not power cycled it since disabling all unused sensors but I have now and it still shows. I am accessing the battery data using a PHP program which issues the calls to the GW1100 as for example Weather Display and Cumulus do it, however it is not fit for purpose to make it public at present. It issues the x"ffff3c033f" command to the GW1n00 and retrieves the messages from the device about all possible enabled devices battery status. Each device enabled shows an ID and if offline shows x'ffffffff' as the ID.
I must stress again at no point can I disable the WH25 it does NOT show up in the sensors id display of either WSview + or the GW1100 web page, so I cannot disable it!
Stuart
Stuart
Offline gszlag
  • ..have you calibrated your barometer today?
    • Michael's Bay - Manitoulin Island weather
« Reply #12 on: January 09, 2022, 03:08:28 PM »
A little off-topic but after reading all the threads about ghost/phantom sensors, I decided to check my system:
1 x GW1000 and 1 X GW1100.
I can confirm that on both consoles (latest firmware) show a WH31 channel #3 (has a registration number)..problem is I don't have a WH31.
I can also confirm that disabling the GW1100 sensor in Wsview does not work...it still showed as "enabled" in the browser UI.
Thanks Gyvate..will be turning off a lot of channels..
Ambient Weather WS-2000
Ecowitt WS3900 console
Ecowitt GW1000/GW1100
Ecowitt WS68: Anemometer, UV/solar
Ecowitt WH40: Rain gauge
Ecowitt WH57 Lightning sensor
Ecowitt WH32E: Outside T & H sensor
Stratus Rain Gauge (manual)
Raspberry Pi 3B+ (WeeWX/CumulusMX)
Raspberry Pi Zero 2W (WeeWX/MQTT/Belchertown)
Barometer wiki: http://meshka.eu/Ecowitt/dokuwiki/doku.php?id=barometer#barometer
http://weather.glenns.ca (pwsdashboard - live)
http://weewx.glenns.ca
http://glenns.ca/cumulusmx2/index.htm
Uploading to: AWN, ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW
Offline kheller2
« Reply #13 on: January 09, 2022, 06:59:27 PM »
Weird.  I had a CH3 Soil Moisture registered on the GW1100 (no signal though, just an ID).  I don't have a 3rd device.  I just hit Re-Register and it went away.
Ambient Consoles: WS-2000, WS-1900, WS-1200, WS-2902C, WS-3000-X3, WS-0900-IP(observerIP), WS-1001-WIFI
Ambient Arrays: WH65B
Ambient Sensors: WH31E(3), WH31B(2), WH32B, WH31SM(2), WH31PGW, AQIN, WH31LA(3)
Ambient Spares: WH24B(2), WH25B.
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Gyvate
« Reply #14 on: January 09, 2022, 07:39:14 PM »
These "ghost" sensor IDs can be remainders of the Ecowitt quality control tests.
Offline gszlag
« Reply #15 on: January 10, 2022, 07:28:11 AM »
Yup. Did the same on my phantom WH31 channel #3 -went away.
All channels are now disabled in the browser UI....will see if the settings hold...
Offline Platokidd
  • top side land of Lincoln
« Reply #16 on: January 10, 2022, 08:58:35 PM »
More off topic as I don't have a ws80 or ws90. After reading the last few postings I thought I would check my gw1100 sensors.
Oddly enough I had one of my soil sensors also show up on the temp soil with the same senor id. However this did not show up in any data. Did a re-register of that sensor id location and it disappeared.
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
