My question is, exactly is the date/time written in the CSV file? Or maybe more specific, how does the date/time show up when it is dropped into an Excel spreadsheet? I'm trying to mock up a spreadsheet and see if the calculations work the way I need them to. The screenshots I can find show the date/time on the display as mm/dd/yy AM 12:00. I'm not sure how to get a formula to work with that format in Excel. I'm hoping the CSV has the date/time in a more usable format.
The CSV-files - written to the SD-card - from my HP2550 console (clone called ProTech) do indeed have that kind of beginning dates on each line... But since I'm Swedish I've chosen another "Date Format" on the "Setup" screen (DD-MM-YYYY) which somehow gets translated to eg "2021/9/30 14:15,22.4,55,11etcetcetc" in the CSV-file (not even a leading zero on the month).
But I would follow the other posters advice and use an external source/software to get the data. It is extremely easy to misalign the SD-card in the slot - and thus lose the card inside of the console. Furthermore, having normal sized fingers one almost have to use tweezers to extract the card. There is such a small lip to pull on.
Mvh,
Mats
As already mentioned earlier, you could use the free CumulusMX software. It can read from your WS-5000 console via the custom server option of the console. It can save the data in its database (= CSV files !!) in a chosen interval (>= 1 minute).
It will depend on the locale of your computer on which you run CMX (Windows, Linux derivte, MacOS) which format of the date will be used, but, date and time will be separate "field" (data item) so you can easily convert in MS Excel if you want.
Like this you avoid the tricky microSD card slot of the console and having to use a 2nd SD card while the one you took out from the console is being processed. It's worth having a look into CMX. And it can handle the Ambient format of your WS-5000 console (as well as the Ecowitt format of the rest-of-the-Fine-Offset-clone-world).
example DE locale:
01.03.22;00:00;3,5;54;-,9;5,42;15,12;172;0,0;0,0;1027,5;234,2;17,6;44;0,00;2,2;3,5;0,0;0;0,00;16,73;-,2;0;0,0;340;0,0;0,0;2,2;3,5
the US locale would be "." instead of "," and "," instead of ";" and "/" instead of "." in the date
01/03/22,00:00,3.5,54,-.9,5.4,15.1,263,0.0,0.0,1027.2,234.3,17.3,47,0.0,2.2,3.5,0.0,0,0.00,22.46,-.2,0,10.3,225,0.0,0.0,2.2,3.5
the description (header line) of the CSV are avilable for the files in the installation (US locale)
Date (dd/mm/yy),Time,Temperature,Humidity,Dew point,Wind speed,Recent high gust,Average wind bearing,Rainfall rate,Rainfall so far,Sea level pressure,Rainfall counter,Inside temperature,Inside humidity,Current gust,Wind chill,Heat Index,UV Index,Solar Radiation,Evapotranspiration,Annual Evapotranspiration,Apparent temperature,Max Solar radiation,Hours of sunshine,Wind bearing,RG-11 Rain,Rain Since Midnight,Feels Like,Humidex
