Author Topic: HP2551 console firmware 1.7.7 available  (Read 172 times)
Offline Gyvate
« on: December 31, 2021, 09:07:08 AM »
Download at
https://www.ecowitt.com/shop/goodsDetail/173#
V1.7.7  main change contents:
    French Language Supported. For this we have many thanks to Benjamin Oget, and his help on the translation made this Langauge supporting possible.
     SD card status displayed. When there is SD card inside, a SD card symbol will  be lit.  If the SD card is not readable or writeable, there will be an indicator to tell the SD card status.
The SD card symbol will appear between the signal of the WS80 and the 'drops' of the WH55 sensors.
Also, the WN34 and WN35 sensors should be shown at the main display page.
The WH45 temperature and humidity will also cycle with the the standard indoor T/H and the WH31 family sensors.
« Last Edit: December 31, 2021, 09:18:28 AM by Gyvate »
