@DelChard
Are both gw1100 receiving the same ws80 sensor?
Or is one gw1100 receiving the ws80 sensor ( the one that show the intermittent failure ) and one gw1100 is receiving another sensor ( a ws80 or a different one )?
For clarity I will refer to Gateway and Gateway 2 (this is how they are named on ecowitt, although Gateway 2 is private).
The set up was:-
Gateway receives its outdoor T & H from a WH32EP (with the sensor located in the shade) , So far this Gateway has never shown spurious readings, despite ( in my book ) being closer to EMR sources (Synology NAS, Asus Router, Cyberpower UPS, all within 1m)
The UPS supplies a surge protected multiway socket supplying all the devices. The Gateway receives its power via the supplied cable from a USB port on the Asus router.
Gateway 2 receives its outdoor T & H from the WS80 ( for no other reason than curiosty).
Gateway 2 located in conservatory, Powered from a mutiway socket (not surge protected).
Potential EMR sources (WH41 located in the conservatory 1m away). (TV, Soundbar, Humax box, Ruark music streamer/DAB radio, Cordless phone, Located in lounge 3m away through cavity wall).
As per previous post, the locations of Gateway and Gateway 2 have now been transposed. I have left the sensor configurations alone.
I have now made Gateway 2 public (
https://www.ecowitt.net/home/index?id=69557)
Gateway (
https://www.ecowitt.net/home/index?id=68583)
And all sensor descriptions include all info.
Gateway was purchased on Amazon, seller ecowitt.eu on 8th Dec
Gateway 2 was purchased from Weather Spares as part of GW1103 bundle on 20th Dec
I suspect they are different manufacturing batches
I'm attaching a messy chart from Gateway 2 showing the very worst error (the data is no longer available, as I deleted and re-added the device)
I'll post back in about a week, wilth how the results of the transposition work out.
Hope this might prove useful to others.
All units are 868MHz
Just in case anyone notices the wind speed differences (I've been playing with wind shear formulas, Gateway 2 has a gain factor applied)
