Author Topic: VWS and Soil Temp  (Read 1738 times)
Offline daybreak
    • Alma Weather
VWS and Soil Temp
« on: December 25, 2021, 06:41:28 PM »
Hello Everyone and Merry Christmas,
I just installed another Davis Sensor Transmitter to use with a soil temperature probe.  It's showing up on my Davis console as station 3 temp.  (which I setup).  But when I try to display the station 3 temp in VWS it's nothing but zeros.  Is there something I'm missing?  Do I need to tell VWS there's another station?  Thank you.
Richard
Offline SteveFitz1
    • Tyler Texas Weather
Re: VWS and Soil Temp
« Reply #1 on: December 25, 2021, 08:02:35 PM »
Just to clarify, the transmitter ID you use is set by the dip switches in the remote transmitter. You mentioned this is #3. The temp and humidity values that VWS returns are called "Channel X Temperature" or "Channel X Humidity" where 'X' is between 1 and 4. These values come from the corresponding position you plug the temp/humidity sensor wires into in the remote transmitter. On my system, my transmitter uses ID #3. I have 2 temp and humidity sensors in the first 2 sensor slots of each type. These show up in VWS as Channel 1 Temperature, Channel 1 Humidity, Channel 2 Temperature, and Channel 2 Humidity.
Steve
Offline daybreak
    • Alma Weather
« Reply #2 on: December 26, 2021, 08:08:58 AM »
Steve,
Thank you!  I was beating my head against the wall with VWS.  I thinking it would be Channel 3 temp!  Thanks for your response.
Richard
Offline daybreak
    • Alma Weather
« Reply #3 on: December 26, 2021, 10:20:58 AM »
Hi Steve,
If you don't mind I have one more question.   :grin: :grin: Are the channel one temperatures not in tenths of degrees?  For example my outside temp will show 48.2 etc  The soil probe shows 48.0 degrees.  I have it set for one decimal place but it's always zero.  Same way on the Davis Console.  It's no big deal, just curious.  Thanks.
Richard
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #4 on: December 26, 2021, 01:42:57 PM »
Check this thread. Hope it helps.
https://www.wxforum.net/index.php?topic=35329.0
Offline SteveFitz1
« Reply #5 on: December 26, 2021, 02:48:38 PM »
Hi Steve,
Richard
Hey Richard,
Since the data is coming via the console, you're seeing it correctly with one decimal place that is ALWAYS 0.
I happen to have a Weatherlink Live receiving data from my Vantage Pro 2 in addition to receiving data at the console. Just now, when I view the data for Channel 1 temperature, VWS shows 64.0 while WLL shows 63.8. I don't really understand why Davis chose to report the data differently on the console.
Steve
Offline daybreak
    • Alma Weather
« Reply #6 on: December 26, 2021, 02:54:36 PM »
Thanks Garth & Steve.
