Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48677 times)
Offline giusCB
  • www.turismometeo.it
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #875 on: October 14, 2023, 03:17:34 PM »
is there a change on piezo sensor ? It's more accurate ? the old one is gold in color, the new one is different...
www.turismometeo.it
Offline Gyvate
« Reply #876 on: October 14, 2023, 03:32:28 PM »
what does "old" mean here compared the "new" apart from the colour of the three round sensor elements ?
New = released/sold since when ?
So far I knew only old (=-version) vs. new - and the main hardware difference were the detectors in the circle around the central solar sensor which are part of the "piezo sensor". The -version had only one (and shorter) segment, the new(er) ones had two opposite to each other.
Offline Gyvate
« Reply #877 on: October 15, 2023, 03:32:56 AM »
as per Ecowitt there is no technical difference between your old/new hardware
"They are actually same. The only difference is that the plastic part under the piezo sensor has meshing surface treatment, and also the glue for sensor mounting has changed. "
Offline giusCB
« Reply #878 on: October 15, 2023, 02:08:56 PM »
 [tup] [tup]
www.turismometeo.it
