Author Topic: Difference between GW1000, GW1000B, Gw10003, GW110  (Read 360 times)
Offline tree311
« on: September 30, 2021, 04:08:13 PM »
Have been hunting for the difference between the units listed above for a while now. Seems there may have been a processor change in there somewhere.
Offline Gyvate
Re: Difference between GW1000, GW1000B, Gw10003, GW110
« Reply #1 on: September 30, 2021, 08:04:14 PM »
There are only GW1100 and GW1000 as gateway consoles (displayless) - a GW10003 or GW110 doesn't exist.
For the A, B, C please read our central thread: https://www.wxforum.net/index.php?topic=40730.0
GW1001, GW1002, GW1003 are stations (GW1000 console + different sensors), not gateway consoles.
see also the thread above.
The only difference between the GW1100 and the GW1000 gateway is that the GW1100 has more memory and therefore has space for its WebUI. The production of the GW1000 has been discontinued, however you may still be able to purchase clone models from Misol (433 MHz), Froggit, ProTech (868 MHz) etc.
Offline tree311
« Reply #2 on: September 30, 2021, 10:20:16 PM »
Thanks for the link. Much better understanding now. Thanks.
