Author Topic: Firmware update ultrasonic anemometer WS80 available  (Read 3185 times)
Online olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3800C
    • FOSHKplugin
« on: September 07, 2021, 01:03:01 AM »
Hi!
There is now a firmware update for the WS80 that fixes various problems (e.g. the occasional peaks of 144kmh):
WS80 firmware upgrade available
During rain time, sometimes abnormal wind speed was detected due to water accumulation influence to the hardware.
We improved the signal qualification process and have the data filtered more precisely for those untable siganl influence.
The new firmware has been tested in Australia and New Zealand during raining time and heavy wind condition, and after about two weeks testing, there is none error wind data detected. So we believe this version solved this problem in a very good way.
Please download the tool kit and read the instructon carefully. It needs a PC with windows system as the tool for firmware update is with PC version only. No MAC system tools available at the moment.
The firmware update software requires a Windows computer.
Direct link.
Oliver
Offline giusCB
  • www.turismometeo.it
Re: Firmware update ultrasonic anemometer WS80 available
« Reply #1 on: September 07, 2021, 04:54:56 AM »
i recently received a ws80 with the latest hardware changes, how do i know if i need to update the firmware? How do I find out what firmware I currently have?
www.turismometeo.it
Online olicat
    • FOSHKplugin
« Reply #2 on: September 07, 2021, 05:12:21 AM »
Hi!
I don't know, but I would expect that you can recognize this from the version number in the upper right corner after connecting to USB.
The current update reports version 0x0200.
But since you then already have the anemometer on the table you could just install it (over).
I dont think that you see the installed version while it is mounted on the pole.
Oliver
Offline giusCB
« Reply #3 on: September 07, 2021, 05:43:15 AM »
is there a possibility to read the contents of the dfu file?
www.turismometeo.it
Online olicat
    • FOSHKplugin
« Reply #4 on: September 07, 2021, 06:08:30 AM »
Hi!
You can convert the DFU file to S19, HEX and BIN with DfuFileMgr.exe (available after installation of the install package from Ecowit).
But I did not see any way to read out the version from the WS80 for comparison.
Oliver
Offline zoomx
« Reply #5 on: September 08, 2021, 07:16:58 AM »
I see that inside there is an STM MCU!
Offline solartempest
« Reply #6 on: September 08, 2021, 12:42:00 PM »
No, you would need the original source code for the firmware.
Unrelated to that, this is exciting to learn that there is a STM32 in the WS80. Lots of space available for features - just 34kb used only! For the step to hit reset to enter bootloader mode, I found that pointed tweezers worked well as the pushbutton is very small.
STM32 MCUs are very difficult to get now and prices have risen by a large amount with the pandemic so I wonder if the chip shortage will impact Ecowitt's prices.
While this is the easiest way to flash firmware, I am also a bit amused that Ecowitt didn't spend the extra effort to develop a fancy branded interface. I use similar tools for flashing my own custom firmware in another hobby so it just caught me by surprise!
Ecowitt GW1000, HP2553BC, WS80, WH51x4, WH41, WH45, WH40, WH32, WH31x2, WH57x2.
Offline zoomx
« Reply #7 on: September 08, 2021, 01:39:37 PM »
Space available depends on STM32 MCU type. There are also chinese clones.
« Reply #8 on: September 08, 2021, 01:58:19 PM »
Has anybody or yourself taken apart a WS80 to verify the chip markings?
And yes, the flash memory size depends on the MCU but typically these are 128kb minimum with a small amount set aside for EEPROM. If it's a counterfeit or clone chip, that might be pared down for cost savings.
Offline eliteweathernz
  • Weather Enthusiast/ Weather Equipment Support
« Reply #9 on: September 09, 2021, 04:01:22 AM »
Hey guys,
I was the tester for the firmware upgrade here in New Zealand.
It took 3-4 variations in firmware to come to this version.
Which has been performing very well, high winds and rain don’t seem to affect the sensor any longer and stable wind speed and direction data is being observed.
If any has any questions I’m happy to answer.
Offline A1cntrler
« Reply #10 on: September 14, 2021, 10:22:29 AM »
Does this update apply to Ambient versions of the WS80?
Ambient WS-5000 (KVACHEST93)
Offline broadstairs
« Reply #11 on: September 25, 2021, 05:03:42 AM »
I have installed this on my WS80 and it runs fine, however I wonder if the solar and UV part of the f/w has been modified? I have had to reduce these values in the calibration section prior to this update and now find I need to remove my adjustments as the values were too low after the update.
Stuart
Offline Gyvate
« Reply #12 on: September 25, 2021, 05:34:56 AM »
Difficult to say.
Best would be to send an email to both Ambient AND Ecowitt (support@ecowitt.com) asking this question (and report the answer back here  8-)).
Offline Gyvate
« Reply #13 on: September 25, 2021, 08:44:49 AM »
Stuart
It must have been modified - now my HP2551 console is updating the solar radiation every 5 seconds (probably 4.75  ;)) what wasn't the case before.
Wind data were updated every 5 seconds before too, but solar data not.
Wondering if this is also the case for the T/H data, but the changes are usually too little to produce visible changes in this interval.
Offline JoPu
    • Puttkammer Wetterstation
« Reply #14 on: December 03, 2021, 04:34:06 AM »
I installed the WS80 Upgrade Tool Kit, connected the WS80 with the Windows PC and startet the DfuSe-Prog.
There was no available DFU Device?
What to do?
Offline giusCB
« Reply #15 on: December 03, 2021, 04:39:53 AM »
Close the program and install correct driver
www.turismometeo.it
Offline JoPu
« Reply #16 on: December 03, 2021, 11:22:46 AM »
After installing the  USB driver of STM32 the DfuSE-Prg. works.
No update is necessary.   :-)
Offline wardie
« Reply #17 on: December 12, 2021, 04:21:57 PM »
Just upgraded successfully. Had a difficult moment as I could not for the life of me get the WS80 in DFU mode upon reset. After a few tries I realised the USB cable I was using was some bespoke rubbish from another gadget that delivers power only not data. When using a normal USB cable it worked fine. Relatively quick and the tool is clear. Now have to see if it addresses my historic spike issues vs WS68.
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
Online olicat
    • FOSHKplugin
« Reply #18 on: December 23, 2021, 03:36:12 AM »
Hi!
There's a new firmware update V1.2.0 available addressing problems with temperature & humidity:
For sensors that are produced with the STH40 sensor, it is possible that the sensor bus line might be a conflict due to working window overlapping. so we have this version released for the upgrade.
If your sensor shows/ed -- of temperature and humidity reading from time to time, we suggest you upgrade this version.  If your sensor never displayed this problem, your sensor might be produced with a sht30 sensor, and it is not necessary.
https://www.ecowitt.com/shop/forum/forumDetails/405
direct link to the update-package
Apparently the T/H sensor has been swapped from the SHT30 to the SHT40 in the meantime. I wasn't even aware of that.
Regards, Oliver
Offline ullises
    • Real Time weather info
« Reply #19 on: December 24, 2021, 03:39:07 AM »
Hi , firmware update didnt work for me as i got two 144 kmh errors in the past month (rain and wind over 60 kmh ) , so i wrote to support on their website. Here's the reply. Maybe more people should ask Ecowitt to be able to edit the wind graphic to correct the errors.
"Hi, Vlad
I am sorry for this problem. But I think your request is reasonable. I have passed this request to our web designer.
Best Regards
Ecowitt Support Team"
Offline giusCB
« Reply #20 on: December 24, 2021, 05:05:43 AM »
the new fw. it work correctly only with the new version of the ws80 ( the version with covers on transducer). On the older one it doesn't fix the wind spike problem during the rain events (tested)
www.turismometeo.it
Offline giusCB
« Reply #21 on: December 24, 2021, 05:07:58 AM »
Hi!
Regards, Oliver
the newer ws80s has removable sensor, i think there is built in sht40 version on it. Can anyone upload a photo of this new sensor ?
www.turismometeo.it
Offline Gyvate
« Reply #22 on: December 24, 2021, 10:35:37 AM »
How do you know it's a newer version (apart from the transducer cover) ?
Any serial number, type specification ?
Or only by being able to easily disassemble it (the T/H unit) ?
🌲🎄 Buon Natale ! 🎄🌲
Offline DelChard
« Reply #23 on: December 24, 2021, 11:30:37 AM »
Just installed a WS80 that shipped from Ecowitt in November.
Its reporting an outside temp of 140F and no humidity reading.Suspect this must be a newer unit.
I use a WH32 EP fpr outdoor temp, this reports a more believable 50F
It's pitch black outside, but if no one else posts pictures before hand, I'll try tomorrow.
Assuming it's not tipping down.
Offline Gyvate
« Reply #24 on: December 24, 2021, 11:42:11 AM »
What are the other values like (sun radiation, wind ...) ? - normal or also "weird" ?
I think a reset could be helpful.
Begin with the "warm" reset using the reset hole and the opened end of a staple.
If this doesn't bring in any change, you will have to do the "cold" reset:
- take down the sensor array (WS80)
- take off the batteries
- put black tape on the solar panel
- wait until the array stops transmitting (could take 2 days) - when the console doesn't receive any reading and the little LED is extinguished. That's necessary as the super capacitor still provides power - it needs to expire first - hence the 2 days.
- then put in the batteries again
- check the values transmitted before you put it up again
If you get still astronomical values, ask Ecowitt for a T/H replacement unit. (if it was shipped in November, it should be the revised hardware already)
If after the T/H unit replacement the values are still too high, ask for a complete array replacement.
