Author Topic: 7in1 Outdoor sensor no wind speed data.  (Read 522 times)
Offline lemuba
    • Fitzbek-Wetter.de
« on: March 14, 2021, 03:42:27 PM »
my 7in1 outdoor sensor stopped transmitting the wind speed data in December time frame.
One day back working in January.
https://www.ecowitt.com/shop/goodsDetail/7
https://www.fitzbek-wetter.de/pwsWDxx/PWS_index2.php
https://www.fitzbek-wetter.de/pwsWDxx/PWS_graph_xx.php?period=year&type=wind&script=wind_c_block.php
Has anyone experienced the same fault in the past, or just bad luck on my station?
Will return the sensor to Froggit/Germany the next days, but first await the delivery of a spare sensor I ordered totay.
Br,
Lemuba
« Last Edit: March 14, 2021, 03:44:35 PM by lemuba »
Offline lemuba
    • Fitzbek-Wetter.de
Re: 7in1 Outdoor sensor no wind speed data.
« Reply #1 on: March 17, 2021, 12:19:43 PM »
To finish this thread, I got it fixed by myself :grin:
1. Recognizing that Froggit only provides 1/2 year warenty, I orderd an new sensor
2. The wrong one #-o But the WH1080SE Sensor in parts compatible [tup] But of course not the main PCB with the DP1500 Dongle. It get´s connected but with wrong/strange meassurments...
3. But also recognizing, that Froggit sells meanwhile only a 3 wing outdoor sensor with the DP1500 - Hmm?:
https://www.froggit.de/?cat=c40_DP-Serie--WiFi-Wetterserver-Bridge--dp-serie.html&cPath=40&page=2
4. Also recognizing that Froggit does not offer the original WH-4000SE two wing sensor as spare part.
Finally I switched over the WH1080SE Wind speed and direction gauge to the old WH-4000SE sensor and everything working fine again [tup] [tup]
Best regards,
Matthias
« Last Edit: March 17, 2021, 12:27:40 PM by lemuba »
Offline Gyvate
« Reply #2 on: March 17, 2021, 07:11:52 PM »
Not fully correct:  ;)
https://www.froggit.de/product_info.php?info=p376_ersatz-ausseneinheit-wh4000se--868mhz-.html
No functional difference between Bi-wing and Tri-wing, just shape (and bi-wing gives less space to birds and snow).
Froggit gives one year warranty (German: Gewährleistung, different legal term than German:"Garantie")
But, as per the law, after 6 months the complainer has to prove that the defect was already there when delivered.
Here Froggit are very rigorous and show little good-will attitude (German: Kulanz).
Therefore, if someone needs a new WH65 in Europe, I keep on suggesting buying the SBS-WS-600 for 98 EUR at expondo.de where a 3-year warranty by the reseller (Steinberg Systems) is offered and the price is just 10 EUR more than the replacement WH65 from Froggit (however you get a WH65 [3-wing],  a WH2650 (=GW1000) and a WH32B (T&H&P sensor which the GW1000 has inbuilt).
[before Christmas the offer was even 66 EUR, unbelievable]
