Author Topic: Weather34 Aurora MKII forecast issue  (Read 520 times)
Offline new2ark
    • AW1401-IP  Home • Weather • Station
« on: January 21, 2021, 01:56:44 PM »
24-72 hour outlook shows no data...
« Last Edit: January 21, 2021, 01:58:15 PM by new2ark »
Offline Gyvate
Re: Weather34 Aurora MKII forecast issue
« Reply #1 on: February 02, 2021, 01:22:22 PM »
It appears that in the 31-Jan-2021 release of Aurora MKII the 3-day forecast can no longer be selected.
If it was possible before and you have it still in your settings file, that may be the reason. It calls a no longer fully functional script
which then doesn't display any data. And the headline is still from your last saved settings.
If you try to update your position 12 in the settings, you shouldn't find it anymore - and if you save it with a new selection
(out of the offered ones), they should show then instead.
That's my observation here.
