I finally took the plunge and ordered the Ecowitt HP2553 along with the WH31B sensor. Thank you Lucy, you're and angel!
Here's my big mistake. I ordered the WH31 for the outdoor temp/humidity. Couldn't figure out why it wouldn't register on the outdoor display. Upon further reading, I should have ordered the WH32. Was that my mistake? If so, I want to order the WH32, but upon reading the specs, it shows the low temperature range is only reads down to 14 ° F. Is that correct? Winter time temperatures get a lot colder than that. My question is, should I order the 32, or is there another sensor that would be better?
2nd question........... I also ordered the WH68 wind sensor. When reading the assembly instructions, it says that the solar panel should be facing north. I thought a southern exposure in the USA would be better. Any thoughts on that?
Thanks for any feedback on those two sensors.
Doug
