Author Topic: GW1000 not sending data to ecowitt.net  (Read 725 times)
Offline tweatherman
« on: October 27, 2020, 05:19:19 PM »
GW1000 stopped updating to the ecowitt.net site. I still can see current live data though the WSView app via the device list. Any ideas out there?
Edit:I had to manually reset it then it finally started to update to the web site again.
tweatherman
« Last Edit: October 27, 2020, 07:10:37 PM by tweatherman »
Offline f00ntic
Re: GW1000 not sending data to ecowitt.net
« Reply #1 on: January 11, 2021, 01:36:10 AM »
Hello, do you see your weather data on the ecowiit map?
I have GW1000 + WH31, but not view its data on the ecowitt map (only location icon).
Offline Gyvate
« Reply #2 on: January 11, 2021, 03:36:30 AM »
That's perfectly normal - on the map you can only see the sensors shown on the top left, those are all outdoor sensors - and the WH31 doesn't belong to them.
(Assuming that that's your only outdoor sensor).
But on the dashboard the WH31 should be visible (when active) together with all other sensors you have  - at least indoor temperature and humidity and pressure from the GW1000 probe.
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpec Rad02
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline f00ntic
« Reply #3 on: January 11, 2021, 03:48:23 AM »
I understand, thank you very much!
