Author Topic: CWOP Export failing  (Read 2950 times)
Offline twofus
Re: CWOP Export failing
« Reply #50 on: September 21, 2020, 12:35:54 PM »
Wifilogger, any update?
I though I have sent you private message with firmware :(
I have published firmware 2.34. Please go to SETUP->SYSTEM and click on update.
After firmware update will be 2.34.
Please try if uptime is ok with CWOP running.
-- Firmware updated to 2.34
-- Export settings remained intact for CWOP (set at 5min) and Weather Underground. Unit reboot after install
-- After 30 min of uptime I added Weatherlink data export settings. Unit did *NOT* reboot, after settings saved
-- Uptime now 1:10:05 and all data exports continue to work
Good job WifiLogger-- the fix appears to be working. Later today I'll reset the unit to clear settings and then test adding data export settings back in and saving instead of the settings already having been in the system as it was after I updated the firmware to see if it works out of the box too.
 :thumbsup:
Offline twofus
« Reply #51 on: September 21, 2020, 12:49:44 PM »
WifiLogger1 bit the dust and we had to order a wifilogger2 from Ryan.
What happened to your first unit?
Miissed this. Not sure what happened - it died after a power surge although the console is plugged into a surge protector (light didn't work any more and reset did nothing. I did not know how to factory reset the unit at that time as you showed me after I uploaded the video so it might still be ok... I haven't tried that).
Offline WiFiLogger
« Reply #52 on: September 21, 2020, 04:34:53 PM »
Could you send it back to me?
