Author Topic: 2902a, Solar Radiation and UV inconsistent  (Read 297 times)
Offline ckqualls
« on: April 29, 2020, 11:21:18 AM »
I have a 2902a, and the readings for Solar Radiation and UV are inconsistent.
Now, at 10am, its gone from 61,000 lux down to 6,000, UV from 2 to 0. Eventually it will go back up. This has been occurring ever since station was installed.
Station has no trees or any other obstacles nearby.
Any ideas?
Re: 2902a, Solar Radiation and UV inconsistent
« Reply #1 on: April 29, 2020, 02:13:06 PM »
Well as clouds move in and out this is normal.
Also if there is any dew condensation readings are affected a bit as the sun comes up after it has rained over night or early morning until it evaporates.
Offline wardie
« Reply #2 on: April 29, 2020, 06:00:21 PM »
I have one of these and can compare it daily to a very big light meter I have, my solar PV installation... I find it tracks pretty well, see attached dashboard example - PV in green (inverted), PWS light meter in yellow. The difference early morning is due the orientation of my PV panels not generating much in the morning.
Sent from my iPad using Tapatalk
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
