This is a quick guide to the new tipping spoon assembly for the VP2. I've started this as a separate thread so as to make the information easy to find.
Firstly this is not a "how-to" for calibrating a rain gauge, merely how to adjust the spoon especially as it seems Davis think you can't do it.
The spoon assembly is essentially a larger version of the one used in the Vantage Vue ISS
The spoon assembly
The reed switch - sealed unlike the old type but with the same pin-out
The magnet and adjusting screw, the closer the screw end is to the magnet the more water it takes to tip the spoon
Remove this screw and the spoon mechanism comes away from the base
The adjustment screw on the underside of the mechanism, turn anti-clockwise to reduce the amount of water before the spoon tips (increase rainfall sensitivity) and clockwise for the reverse.
