Dale:
The BME280 I2C sensor I’m using for pressure and indoor temperature runs as a data service. Its data is placed in the loop approximately every 3 seconds, then archived every 5 minutes. Additionally, I have AS3935 module which its data is archived every 5 minutes.
Mar 13 21:01:14 DavisSDR weewx[10852]: rtldavis: chan: 21:01:13.963487 Hop: {ChannelIdx:27 ChannelFreq:915966601 FreqError:1047}
Mar 13 21:01:16 DavisSDR weewx[10852]: rtldavis: data: 21:01:16.525335 E00686380200B67A 14861 0 0 0 0 msg.ID=0
Mar 13 21:01:16 DavisSDR weewx[10852]: bme280: BME280 data compensated_reading(id=12223927-88c4-478e-bba3-86d8b1198c5a, timestamp=2020-03-13 21:01:16.596241, temp=24.542 °C, pressure=958.22 hPa, humidity=0.00 % rH)
Mar 13 21:01:16 DavisSDR weewx[10852]: bme280: {'txBatteryStatus': 0, 'rain': 0.0, 'dateTime': 1584147677, 'windDir': 188.78656126482213, 'windSpeed': 3.1292722222222222, 'inHumidity': 0.0, 'inTemp': 24.542357759928564, 'usUnits': 17}
Mar 13 21:01:16 DavisSDR weewx[10852]: rtldavis: chan: 21:01:16.525992 Hop: {ChannelIdx:38 ChannelFreq:921485856 FreqError:-1100}
Mar 13 21:01:19 DavisSDR weewx[10852]: rtldavis: data: 21:01:19.087819 500487FF7100818C 14862 0 0 0 0 msg.ID=0
Mar 13 21:01:19 DavisSDR weewx[10852]: bme280: BME280 data compensated_reading(id=6b298b16-48b1-4547-bb5b-da5289e675b6, timestamp=2020-03-13 21:01:19.126320, temp=24.528 °C, pressure=958.12 hPa, humidity=0.00 % rH)
Mar 13 21:01:19 DavisSDR weewx[10852]: bme280: {'txBatteryStatus': 0, 'dateTime': 1584147679, 'windDir': 190.13833992094862, 'windSpeed': 2.2351944444444443, 'inHumidity': 0.0, 'inTemp': 24.52764487231616, 'rainRate': 0, 'usUnits': 17}
Mar 13 21:01:19 DavisSDR weewx[10852]: rtldavis: chan: 21:01:19.088838 Hop: {ChannelIdx:10 ChannelFreq:907436843 FreqError:1047}
Mar 13 21:01:21 DavisSDR weewx[10852]: rtldavis: data: 21:01:21.650837 400286FFC3005856 14863 0 0 0 0 msg.ID=0
Mar 13 21:01:21 DavisSDR weewx[10852]: bme280: BME280 data compensated_reading(id=5d60b377-9cf5-41af-b9f8-cffa096f13fb, timestamp=2020-03-13 21:01:21.706911, temp=24.523 °C, pressure=958.16 hPa, humidity=0.00 % rH)
Mar 13 21:01:21 DavisSDR weewx[10852]: bme280: {'txBatteryStatus': 0, 'dateTime': 1584147682, 'windDir': 188.78656126482213, 'windSpeed': 0.8940777777777777, 'inHumidity': 0.0, 'inTemp': 24.522740577027434, 'usUnits': 17}
Mar 13 21:01:21 DavisSDR weewx[10852]: rtldavis: chan: 21:01:21.651479 Hop: {ChannelIdx:49 ChannelFreq:927005112 FreqError:422}
Mar 13 21:01:24 DavisSDR weewx[10852]: rtldavis: data: 21:01:24.213602 8003861D4B001057 14864 0 0 0 0 msg.ID=0
Mar 13 21:01:24 DavisSDR weewx[10852]: bme280: BME280 data compensated_reading(id=f231c608-2416-4583-b7a9-028f00ab401a, timestamp=2020-03-13 21:01:24.263928, temp=24.537 °C, pressure=958.27 hPa, humidity=0.00 % rH)
Mar 13 21:01:24 DavisSDR weewx[10852]: bme280: {'txBatteryStatus': 0, 'pressure': 958.265786001613, 'dateTime': 1584147684, 'windDir': 188.78656126482213, 'outTemp': 8.222222222222221, 'windSpeed': 1.7881555555555555, 'inHumidity': 0.0, 'inTemp': 24.537453463766724, 'usUnits': 17}
Don’t know if you searched the following group but you might find useful information there
https://groups.google.com/forum/#!forum/weewx-development
