« Reply #51 on: November 14, 2019, 05:47:09 PM »
Rain Gain is 1.0
.254mm makes sense
Tip 1 = .254 rounds to .3mm
Tip 2 + .254 = .508 rounds to .5mm
Tip 3 + .254 = .762 rounds to .8mm
Tip 4 + .254 = 1.016 rounds to 1.0mm
« Last Edit: November 14, 2019, 05:50:20 PM by _John C »
Ecowitt GW1000CA x2, HP2551CA, WH65 Outdoor 7in1 2 arm array, WH32B Indoor Temp/Hum/Baro, WH45 Co2/PM2.5/PM10, WH41 PM2.5, WH57 Lightning Detector, WH31 Temp/Hum x8, WN34L Liquid Temp x2, WN34S Soil Temp x1, WH51 Soil Moisture x8, WH55 Water Leak x4, Meteobridge (TL-WR902AC v3), Da9L PWT x2, Home Assistant Integration
