Thanks for the suggestions.
I think I would add 1.4.0 to the unstable list as i was having issues with the WS-2000 console before acquiring the ATMOCOM. Usually, temp/wind would go blank requiring a hard reset (pull the plug!) in order to get things going again. This occurred a handful of times.
I will update to 1.4.1 as 1.4.0 is just not working well for me.
I have since been in touch with the inventor/developer of the ATMOCOM device and he is suggesting a factory reset of the WS-2000 if my console insists on connecting with my home router. The ATMOCOM manual recommends removing all other SSIDs to prevent possible roaming issues.
Once connected to the ATMOCOM, I am happy to report that the ATMOCOM device has been working flawlessly with the WS-2000 and I haven't had to do a factory reset (so far)of the WS-2000 to get rid of my home router SSID settings.
Interesting thought on the GW-1000. As you can see, I am really avoiding the thought of doing a factory reset but if the issue comes up again, I will do so.
kbellis did an excellent initial review of the ATMOCOM. I'll take up the torch and do up a post about how to setup and use the ATMOCOM with weather templates.
For now I recommend using firmware 1.4.1 on the WS-2000 console. The newer 1.4.2 and 1.4.4 are unstable.
Another option for you to consider to send data to your ATMOCOM is to get the Ecowitt GW1000 as with the newest firmware it can send data directly to the ATMOCOM as it expects with WU protocol without need to be on a captured WiFi SSID network. This is accomplished in the GW1000 by going to Weather Services and filling in the Customized section and pointing it to the ATMOCOM.
