My apologies in advance if I ask obvious questions since I have little knowledge to which is added the language problem (I am using Google Translate)
I just launched the scripts:
https://www.meteosanjuan.com/wx_lvn_wxsimD.phpFirst of all, many thanks to the author for making it easy for those of us who have little programming knowledge with the scripts adapted for the Saratoga templates. Just link in the menu and it's working. I have read something about making a donation, which seems very fair to me since this hobby that many of us share makes me happy.
I want to make some configurations, but I don't know in which script I should do them, because there are two that seem the same to me, they are metric _us and ca_settings.php
I have observed that any change in the configuration script does not have an immediate effect on the web, I have to wait for a new forecast of my wxsim to be made. Would there be a way to see them immediately?
As for the translation into my language, it works perfectly. I understand that it works since the root folder contains plaintext-parser-lang-es.txt, although it is clearly indicated in the manual that a new translation file must be generated. I'm confused about this
The font size is correct from the PC, but it seems too big from the mobile.
And finally, could you start by default, below the meteogram, the icons instead of forecast? I don't know if I understand myself.
That is, this was the default boot, as in the image I attached
Thank you so much
