Author Topic: Weatherbridge Setup - SOLVED  (Read 728 times)
Offline stevealex
« on: December 30, 2018, 02:09:53 PM »
UPDATE: I tried a different serial-usb adapter, and it works now.
Hi bought Weatherbridge and just set it up with my Vantage Pro 2, using a serial to usb adapter I had previously used successfully with a PC. Setup seemed to go ok except I'm not seeing and data in live view. Can anyone tell what the issue is? I appreciate any help, thanks.
This is what I'm seeing under Messages in the System tab:
wnetd (30.12.2018 13:42:17): process started.
system (30.12.2018 13:42:17): start of logging process initiated.
logger (30.12.2018 13:42:18): no historical data loaded.
logger (30.12.2018 13:42:18): data logger (version 5.1a, build 12616) started.
logger (30.12.2018 13:42:18): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:42:22): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.12.2018 13:42:22): services paused.
logger (30.12.2018 13:42:48): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:44:18): message above repeats 3 times.
logger (30.12.2018 13:44:19): give up waiting for sensors after 120 secs.
logger (30.12.2018 13:44:19): services activated.
logger (30.12.2018 13:44:48): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:52:48): message above repeats 16 times.
logger (30.12.2018 13:52:49): child process received timeout signal (14).
logger (30.12.2018 13:52:50): data logger stopped.
logger (30.12.2018 13:52:50): no historical data loaded.
logger (30.12.2018 13:52:50): data logger (version 5.1a, build 12616) started.
logger (30.12.2018 13:52:51): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:52:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.12.2018 13:52:54): services paused.
logger (30.12.2018 13:53:21): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:54:21): message above repeats 2 times.
system (30.12.2018 13:54:22): stop of logging process initiated.
logger (30.12.2018 13:54:22): parent process received termination signal (15).
logger (30.12.2018 13:54:22): child process received termination signal (15).
system (30.12.2018 13:54:22): start of logging process initiated.
logger (30.12.2018 13:54:23): no historical data loaded.
logger (30.12.2018 13:54:23): data logger (version 5.1a, build 12616) started.
logger (30.12.2018 13:54:23): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:54:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.12.2018 13:54:27): services paused.
logger (30.12.2018 13:54:53): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 13:56:23): message above repeats 3 times.
logger (30.12.2018 13:56:24): give up waiting for sensors after 120 secs.
logger (30.12.2018 13:56:24): services activated.
logger (30.12.2018 13:56:53): can't open device /dev/ttyMH: No such file or directory
logger (30.12.2018 14:02:53): message above repeats 12 times.
« Last Edit: December 31, 2018, 04:03:48 PM by stevealex »
Offline wvdkuil
  • Wim van der kuil
Re: Weatherbridge Setup
« Reply #1 on: December 30, 2018, 03:25:43 PM »
Did you install the usb 2.0 hub between the vantage and the Meteobridge?
That is necessary as the MB uses USB2.0 and the vantage components are USB 1.0
Wim
Offline stevealex
« Reply #2 on: December 30, 2018, 04:28:23 PM »
Yes, I'm using the hub.
