Author Topic: $useTopWarning event box color  (Read 549 times)
Offline NorCal_Dan
    • Traveling RV Wx
« on: December 15, 2018, 06:30:32 PM »
Why is my NWS event box color not changing to match the severity of the event?  When I have it set to show all events the box remains yellow all the time.  When set to display only the most severe event it does change color, ie. red for warnings, yellow for watches.
I've researched this extensively and it seems this is how the code, as documented, is suppose to work.  But I know of one station near me where the box does change color AND displays multiple events.
See attachments...
Box changes color -- http://www.beachhouseweather.com/
Box doesn't change color -- http://travelingrvwx.com/
Re: $useTopWarning event box color
« Reply #1 on: December 15, 2018, 06:57:56 PM »
Your site seems to be using atom-advisory/atom-top-warning for display on the home page.
Their site is using the nws-alerts script set to display that box.
You can switch your site to use the nws-alerts version instead by changing your index.php from
<?php // insert desired warning box at top of page
if ($useTopWarning) {
 if (phpversion() < 5.0) {
       include_once(
"rss-top-warning.php");
 } else {
   include_once("atom-top-warning.php");
  } else {
   print
"      <div class=\"advisoryBox\">\n";
$_REQUEST['inc'] = 'y';
$_REQUEST['summary'] = 'Y';
   if (
     include_once(
"rss-advisory.php");
   } else {
     include_once(
"atom-advisory.php");
   print
"      </div>\n";
<div class="column-dark">
to
if(isset($SITE['NWSalertsCodes']) and count($SITE['NWSalertsCodes']) > 0) {
// Add nws-alerts alert box cache file
include_once("nws-alerts-config.php");
include($cacheFileDir.$aboxFileName);
// Insert nws-alerts alert box
echo $alertBox;
<script type="text/javascript" src="nws-alertmap.js"></script>
<?php
  } else {
// use atom scripts of choice
} else {
 print "      <div class=\"advisoryBox\">\n";
 include_once("atom-advisory.php");
 print "      </div>\n";
When nws-alerts was integrated with the template, the older atom-advisory and atom-top-warning scripts were deprecated as the nws-alerts script set provided much more functionality.
Offline yamiacaveman
    • Penn Lake Weather
« Reply #2 on: December 27, 2018, 02:55:46 PM »
Hi Ken,
 I think my alert is working properly, but after reading this post I went back to check the code I had in my index.php
2 things I noticed that are different: I have this at the top of my code,  <div class="column-dark"> as in
$useTopWarning = false;  // set to true to use only the rss-top-warning script
//                         set to false to use the rss-advisory script instead
<div id="main-copy">
And I do not have this line of code:   <script type="text/javascript" src="nws-alertmap.js"></script>
I do have an announce script added in there -- I guess what I'm asking - should I add the above line in there??? below is what I have.
top-warning script
 echo $alertBox;
} else { // use atom scripts of choice
} else {
 print " </div>\n";
<?php
 include_once("./specanounconfig.php"); // include the settings
 include_once($cfolder.$cfile);         // include the cache file
 if(date("U") <= $spandata[1]) {echo $spanmessage;}
<div align="center">
<!--  <br/>
