Author Topic: WH2900 "OZWeather" a tenth of real wind speed  (Read 1069 times)
Offline alexanderwells
« on: December 13, 2018, 12:03:11 AM »
Greetings fellow weatherophiles.
I bought my WH2900 wifi station as an "OZweather" labelled unit - works fine for everything except wind speed.
It displays (and uploads to Wunderground) wind speeds which are about 1/10th of the actual.
Today I have variously verified wind speed at my place of around 45kph - yet my WH2900 screen (and Wunderground summary) shows 4 and 4.5??
Even calibration (factors of 0.5 thru to 1.5) wouldn't change it by this factor. Any brilliant ideas welcome!
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
Re: WH2900 "OZWeather" a tenth of real wind speed
« Reply #1 on: December 13, 2018, 06:39:31 AM »
Have you checked in your wind speed unit settings?
Offline Jim Ace
    • Hewlett Point Beach
« Reply #2 on: December 13, 2018, 07:40:01 AM »
How high is the unit mounted?  20 feet plus for accurate wind speeds,  wind at ground level is much lower.
KNYEASTR4
Ecowitt WS65
AWEKAS 14894
PWS
WeatherCloud
Windy
Weewx
CumulusMX
CWOP FW3861
« Reply #3 on: December 13, 2018, 05:05:34 PM »
Thanks for replying guys....my unit is on a post that's about 2 metres high - exactly the same position as my last WH1900(?) which gave me no problems with wind speed (until it filled up with an ants' nest and stopped working!) During windy weather, it regularly reported speeds of 40 or so kph. My new WH2900 only reports 4 or 5 kph and the cups are spinning madly.
I adjusted the calibration which WAS on a factor of 50% (?!) up to 150%, but even now, it only reports about 6 to 8 kph when I have evidence that at its location point, the wind speed is MUCH higher - around 45kph. My thoughts are faulty hardware.
