HassanMohi, remove the radiation shield and if you see two sensors then:-
the temperature sensor is easy. It is a NTC 10K @ 25C bead thermistor. Make sure you get the 1% ones as a minimum.
As for the humidity sensor, I am not 100% sure, but according to my searches and spec sheets, it looks like it MIGHT be a HR202L.
Hope this help
