Author Topic: about clean rainfall  (Read 1833 times)
Offline NasserAbbas
« on: April 22, 2017, 08:25:42 AM »
Hi guys,
I have a quasation about my weather station
season of rains in my country finish
after how many day can i clean rainfall..??
I am from Bahrain and amount of rains was 6.6 inch this year
« Last Edit: April 22, 2017, 10:26:10 AM by NasserAbbas »
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: about clean rainfall
« Reply #1 on: April 22, 2017, 08:54:23 AM »
Hi Nasser,
what exactly do you mean by cleaning rainfall?
P.S. I now this is a typo, but I would probably change the "gays" to "guys" :-)
Offline NasserAbbas
« Reply #2 on: April 22, 2017, 10:23:02 AM »
I mean slot of rain or region of rain
I hope you understand what I mean
Offline Jáchym
    • Meteotemplate
« Reply #3 on: April 22, 2017, 11:19:10 AM »
Hmm... sorry Im afraid I do not, slot of rain or region?
You mean like when you should "zero" your annual/seasonal rainfall?
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
« Reply #4 on: April 22, 2017, 12:23:00 PM »
(...) after how many day can i clean rainfall..?? (...)
What weather station do you have?
Do you want to clean the rain gauge from the dirt or archived data in a weather station?
« Last Edit: April 22, 2017, 12:26:06 PM by Rychu »
Offline NasserAbbas
« Reply #5 on: April 22, 2017, 03:10:04 PM »
I want to clean the rain gauge from the dirt and the water
I have ambient ws-1001
Offline Jáchym
    • Meteotemplate
« Reply #6 on: April 22, 2017, 03:25:55 PM »
Im not sure I understand why it should be a problem doing it anytime as long as it is not raining - which would mean you might miss some rain, but otherwise I dont think there is anything preventing you from cleaning it :D
Offline Rychu
« Reply #7 on: April 22, 2017, 06:20:00 PM »
I want to clean the rain gauge from the dirt and the water I have ambient ws-1001
As Jachym wrote, rain can be cleaned at any time if you notice that they are contaminated.
Weather data will not be lost. There is no water in the middle of what you expect. There may be spiders and cobwebs. Therefore, insert a grid into the mast tube. If you do not do this, the spiders will migrate the tube directly into the WH24.  ;)
Offline Jáchym
    • Meteotemplate
« Reply #8 on: April 22, 2017, 06:34:28 PM »
Assuming your weather station has a tipping bucket rain gauge, just make sure you unplug it otherwise you will record a lot of rain by just moving and rotating the gauge while manipulating with it. First unplug it, then carefully rinse it and take out any debris and then place it back to its original position and then plug it back in.
Offline DoctorKnow
« Reply #9 on: April 22, 2017, 08:15:18 PM »
I think Nasser is asking how to clean the sensor of the all in one. (Ambient) Maybe someone with that model has tried to take it apart, but I believe that sensor is not designed to be opened up like the acurite... I don't even think it's recommended to clean it.
Offline Jáchym
    • Meteotemplate
« Reply #10 on: April 22, 2017, 08:24:12 PM »
Aaahh.. sorry I misread that, I thought he has a FineOffset
Offline Rychu
« Reply #11 on: April 23, 2017, 01:07:21 PM »
Instruction WS1001 recommends cleaning the exterior of the outdoor sensor - describes how to do it  ;)
« Last Edit: April 23, 2017, 01:08:55 PM by Rychu »
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #12 on: April 23, 2017, 02:08:25 PM »
I've cleaned my ws-1001 using the following procedure found in the manual.
http://site.ambientweatherstore.com/Manuals/ws1001wifi.pdf
There are two methods to clean, one using a cotton swab and the other to open the unit and properly clean out the debris.
When I opened my unit (be careful you don't break sensor wires) it had a lot of debris (bird poop) around the tipping mechanism.
Look at Page 54 and 55 for cleaning.
Have fun :D
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Ambient 1001 | ObserverIP | Meteobridge | MeteoPlug
Offline DoctorKnow
« Reply #13 on: April 23, 2017, 09:10:15 PM »
Nice illustration. I read somewhere a while back that someone tried to take the sensor apart for some reason, and the screws were so tight they couldn't do it. Hopefully that isn't common.
  • Weather Hobbyist
    • Spring Hill
« Reply #14 on: April 23, 2017, 10:07:32 PM »
Yes, I just tried opening a new unit I have and it was very tight to first open, the key was finding the best Phillips head screwdriver to loosen the screws without stripping the head.
Here is the inside view.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
