Author Topic: V14p50 Wind Gust Graph [CLOSED]  (Read 4424 times)
blackjack52
  • Guest
« on: January 27, 2009, 03:04:43 PM »
I have been noticing the Alfa Numeric correctly diisplays the Hi Gust recorded for the day, but my graph does not.
Alfa Numeric Hi Gust 30mph
Graph 28mph [using the past 24hrs]
Gust samples set to 30, Filtered Avg 5 minutes.  I don't think these paraams affect displaying on graphs, just how VWS calculates.  If so, is the reason the Alfa num correctly shows the hi, but the graph does not due to the graph updating every 5 min [my db update period] :?:
I would think when the graph updates every 5 min, it takes the hi for that period.
« Last Edit: February 08, 2009, 02:58:16 PM by MadALwx »
blackjack52
  • Guest
Re: V14p50 Wind Gust Graph
« Reply #1 on: January 28, 2009, 03:36:27 PM »
Nor does the max show in the Wind Distribution.
blackjack52
  • Guest
Re: V14p50 Wind Gust Graph [CLOSED]
« Reply #2 on: January 29, 2009, 04:18:14 PM »
From Ed.
To fix this, change the option to record the highest wind gust in the database update period.
You can find this by selecting Settings | Advanced Parameter Settings.
CLOSED
blackjack52
  • Guest
« Reply #3 on: January 30, 2009, 09:49:56 AM »
Recommendation did not correct.
I made the adjustment yesterday afternoon.  At 123a today, the alfa numeric Max Gust displays 19mph, but the graph displays 18mph.  The actual spd was 19.2mph.   Max wind spd was 18mph in alfa numeric, but graph displays 11mph.
« Last Edit: January 30, 2009, 10:02:49 AM by MadALwx »
blackjack52
  • Guest
« Reply #4 on: January 30, 2009, 10:45:48 AM »
From the software developer,
Here is the issue. The daily high and low may not be in the real time update feed.
Once an hour, VWS looks back at the daily highs and lows for the day (in case it is missing in the live feed) with a different command (which has a lot of overhead).
So this data is obtained after the fact.
Unfortunately, there is no easy way to get this back into the database, but I will look into it.
blackjack52
  • Guest
« Reply #5 on: January 31, 2009, 11:49:14 AM »
Will be fixed in the next release.
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #6 on: February 01, 2009, 07:30:20 AM »
One more reason, I should upgrade.  V13.01 P09 has the same issues.
blackjack52
  • Guest
« Reply #7 on: February 03, 2009, 04:11:06 PM »
Just installed p58.  At 1252p, alfa numeric indicates Gust 37mph and Wind 29mph, but graph only shows Gust 29mph and Wind 19mph which ocurred at 210p.
I sent an email to Ed asking if the patch only applies from the time p58 was installed and onward.
blackjack52
  • Guest
« Reply #8 on: February 04, 2009, 03:32:41 PM »
Windgust will plot the highest speed in the database update period if you turn on the option to get the highs and lows (which I assume you have done) and you choose the option under Settings | Advanced Parameter Settings to update the highest windspeed in the database update period.
Don't worry about windspeed plotting Hi value because it will never do this. It just plots the windspeed at that point in time.
[CLOSED] Fixed by p58.
« Last Edit: February 04, 2009, 03:35:47 PM by MadALwx »
