Am still reading more on the subject - some of what your saying makes sense, other parts - not yet.....that's ok.
the more I'm reading, the more confusing it gets - which is half the struggle.
What confuses me the most, is when you have the direction changing multiple times with the same minute.
Is something changing that drastically that quickly that it's causing those directional changes?
As you stated, I'm talking on the micro scale - (the trees from the forest) - what is changing on the
micro scale?
obviously, this can't be answered in forum post, given all the variables - but which variable would be the one
that changes most frequently that would cause those frequent changes in direction? Obviously the terrain is constant
I can understand the cloud cover allowing more/less solar heat through, but you also have wind shifts when the cloud
cover is the same or non-existant.
Or is it (tongue in cheek) a result of thousands of people going in and out of their homes, with the AC/heat escaping
or entering their homes - cause minute changes....
