There is no lightning rod. Lightning Rods are designed to attract lightning. That's the last thing I desire. That wireless station sits isolated on the 1¼" sectional pipe. The pipe mounts on a tilt base, and the guys are hooked to fence... Nothing touches earth ground. I might possibly get a big pulse through the Blitzortong E Field antenna, and the Hikvision cam mounted on the mast, not in that first picture, other than that, I compute little or no danger. (Now, watch it get blown to smithereens with the next storm...
](https://www.wxforum.net/Smileys/default/eusa_wall.gif)
Now, some folks do use grounds, etc... I dunno... I personally think it's a wasted expense, and effort in
most cases... especially if your equipment manufacturer has no suggestions in their documentation, everything considered... again, if a bolt aims at you, you're cooked anyway,.... stuff may not fail for days or weeks after a near-miss.
...but you have to do what you feel, what is necessary for your area, and what will make you sleep better at night.
Cheers!
Mike
