Ok, I've changed the script to use the new source (pretty much rewrote the bulk of the script).
Now it returns $usahigh, $usalow, and $usaprecip(if >0.00). A few new options are available in the settings in the script, and it does allow units or no-units display.
<?php
# Project: USA Extremes
# Module: usaextremes.php
# Purpose: Provides USA Extremes for Web page display
# Authors: Michael (michael@relayweather.com)
# Ken True (webmaster@saratoga-weather.org) V2.01, V2.02
# Usage: Place the following on your webpage
# CHMOD 666 for cacheFile2.php
# include_once('usaextremes.php');
# Then call the following tags within the page where you would like them displayed:
# $usahigh
# $usalow
# $usaprecip (note: $usaprecip will be 'N/A' in V2.02
# Note: allow_url_fopen = on
# in your php.ini is required to run this script.
// version
// Version 2.00 - 14-Sep-2010 - initial release
// Version 2.01 - 21-Sep-2012 - adapted for WeatherUnderground use - K. True
// Version 2.02 - 23-Aug-2016 - adapted for www.wpc.ncep.noaa.gov - K. True
// Version 4.00 - 11-Sep-2016 - rewrite to use new URL:
// http://www.cpc.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/dly_glob1.txt
$usaextremesverion = "4.00";
echo "<!-- USA Extremes Script Version $usaextremesverion saratoga-weather.org -->\n";
//SETTINGS START HERE////////////////////////////////////////////////////////
// Site to Parse
$url2 = "http://www.cpc.noaa.gov/products/analysis_monitoring/cdus/prcp_temp_tables/dly_glob1.txt";
// Set the time zone
$ourTZ = 'America/New_York';
// Name of cache file -- This file must be set to CHMOD-666
$cacheFileDir = './'; // directory to store cache file in.
$cacheFile2 = "usaextremesCache4.txt";
// Age of cache file before re-fetch caching time, in seconds (3600 = 1 hour)
$cache_life = '3600';
$reportDateFormat = "l, F j, Y"; // Day, Month d, yyyy
$tUOM = '°F'; // or ='' for no temperature unit display
$rUOM = 'in'; // or ='' for no rain unit display
//END SETTINGS///////////////////////////////////////////////////////////////
global $SITE;
if (isset($SITE['cacheFileDir'])) {$cacheFileDir = $SITE['cacheFileDir']; }
if (file_exists($cacheFile2)) {
$filemtime = filemtime($cacheFile2);
$filesize = filesize($cacheFile2);
if (0 == $filesize){
$filemtime = 0;
} else {
$filemtime = 0;
// open the cache file and write the new data and then close the file.
$forceRefresh = (isset($_REQUEST['force']))?true:false;
$current_time = time();
$cache_age = $current_time - $filemtime;
if ($forceRefresh or $cache_age >= $cache_life){
print "<!-- fetching from '$url2' -->\n";
$html2 = curl_get_contents($url2);
$fp2 = fopen($cacheFile2, 'w');
fwrite($fp2, $html2);
fclose($fp2);
echo "<!-- The cache life HAS expired and fresh data re-wrote the cache file -->\n";
} else {
echo "<!-- The cache life HAS NOT expired and fresh data was not written to the cache file -->\n";
// Open the cache file, read it, then close it
$handle2 = fopen($cacheFile2, "r");
$html2 = fread($handle2, $filesize);
fclose($handle2);
function curl_get_contents($url){
$ch = curl_init();
curl_setopt($ch, CURLOPT_HEADER, 1);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/5.0 (Windows NT 6.1; rv:19.0) Gecko/20100101 Firefox/19.0");
$data = curl_exec($ch);
curl_close($ch);
return $data;
/* looking for:
*****NOTE***************NOTE*********************NOTE************************
FILE FORMAT: FIRST RECORD IS DATE IN THE FORM YYYYMMDD. THE REMAINING RECORDS
CONTAIN MAXT(F),MINT(F),REPORTED AND ESTIMATED PRECIP IN HUNDRETHS OF INCHES,
9 WEATHER CHARACTERS,ID AND CITY NAMES WHERE AVAILABLE.
20160910
--- 0---|--- 10---|--- 20---|--- 30---|--- 40---|--- 50---|--- 60---|--- 70---|--- 80---|--- 90---|
123456789|123456789|123456789|123456789|123456789|123456789|123456789|123456789|123456789|123456789|
37 32 1 1 9DSSS////70026 AK BARROW/W.POST W.ROGERS
41 34 20 20 9R/RRSSR/70086 AK BARTER ISLAND/DEW STN
46 39 2 2 9MMM/RRRM70104 AK CAPE_LISBURNE(AWOS)
44 41 1 1 9/D/RMDDD70117 AK TIN_CITY_AFS_(AWOS)
51 46 0 0 9////////70133 AK KOTZEBUE/RALPH WIEN ME
55 33 0 0 9----////70173 AK INDIAN_MTN_AFS_AWOS
90 75 0 0 8/T-//TTT78514 PR RAMEY AFB
90 78 15 15 8/////RR/78526 PR SAN JUAN
90 76 0 0 8///R/RRR78535 PU ROOSEVELT_ROADS_NAS
89 81 122 122 8-/-/-/--78543 IS CHARLOTTE AMALIE VIRGI
84 74 1 1 8////////91066 HI MIDWAY ISLAND NAVAL AI
88 73 0 0 8////////91162 HI KEKAHA, PACIFIC MISSIL
87 78 0 0 8//R/////91165 HI LIHUE
79 68 8 8 8///RR//R91170 HI WHEELER
83 75 12 12 8/////RRR91176 HI KANEOHE
88 73 0 0 8////////91178 HI BARBERS_PT_NAS/OAHU
86 73 4 4 8///R////91182 HI HONOLULU
87 73 0 0 8///////R91186 HI MOLOKUI
88 73 1 1 8///R////91190 HI KAHULUI
84 70 5 5 8/R/RRR//91285 HI HILO/LYMAN_FIELD
91 73 0 0 8//MS////9911R TX BRENHAM, BRENHAM MUNIC
$usahighStation = '';
$usahighValue = -999;
$usalowStation = '';
$usalowValue = 999;
$usaprecipStation = '';
$usaprecipValue = 0;
$usaStations = array();
$reportDate = '';
$rawrecs = explode("\n",$html2); // process the file
$idx=0;
foreach ($rawrecs as $n => $rec) {
if($reportDate == '' and preg_match('/^\s+(\d+)$/',$rec,$matches)) {
$reportDate = gmdate("l, F j, Y",strtotime($matches[1].'T1200'));
print "<!-- reportDate='$reportDate' -->\n";
continue;
$recmarker = substr($rec,19,1);
if($recmarker == '9' or $recmarker == '8') {
list($tHigh,$tLow,$tPrecip,$tPrecipEstim,$tData,$tState,$tStation) =
sscanf($rec,' %d %d %d %d %s %s %[^\n]s');
$tStation = strtolower( trim($tStation) );
$tStation = str_replace('/','| ',$tStation);
$tStation = ucwords( str_replace('_',' ', $tStation) );
$tStation = str_replace('| ','/',$tStation);
if(isset($_REQUEST['debug'])) {
print "<!-- rec='$rec' -->\n";
print "<!-- tHigh='$tHigh' tLow=$tLow, tPrecip='$tPrecip', tPrecipEstim='$tPrecipEstim',";
print " tData='$tData', tState='$tState', tStation='$tStation' -->\n";
$usaStations[$idx] = join("\t",array($tHigh,$tLow,$tPrecip,$tPrecipEstim,$tData,$tState,$tStation));
$idx++;
// now scan for the highs/lows
if (count($usaStations) > 0) {
$usahigh = '';
$usalow = '';
$usaprecip = '';
} else {
$usahigh = 'N/A';
$usalow = 'N/A';
$usaprecip = 'N/A';
foreach ($usaStations as $n => $vals) {
list($tHigh,$tLow,$tPrecip,$tPrecipEstim,$tData,$tState,$tStation) = explode("\t",$vals);
if($tHigh < -90 or $tLow < -90 ) { continue; }
if($tHigh > $usahighValue) {
$usahighValue = $tHigh;
$usahighStation = $n; // remember for later
if($tLow < $usalowValue) {
$usalowValue = $tLow;
$usalowStation = $n; // remember for later
if($tPrecip > $usaprecipValue) {
$usaprecipValue = $tPrecip;
$usaprecipStation = $n;
print "<!-- usahighValue=$usahighValue station=$usahighStation ".$usaStations[$usahighStation]." -->\n";
print "<!-- usalowValue=$usalowValue station=$usalowStation ".$usaStations[$usalowStation]." -->\n";
print "<!-- usaprecipValue=$usaprecipValue station=$usaprecipStation ".$usaStations[$usaprecipStation]." -->\n";
// now pass through to see if any duplicate high, low, high precip exists and format the strings
if($tHigh == $usahighValue) {
$usahigh .= "<b>$tHigh$tUOM at $tStation, $tState</b>\n";
if($tLow == $usalowValue) {
$usalow .= "<b>$tLow$tUOM at $tStation, $tState</b>\n";
if($tPrecip == $usaprecipValue and $tPrecip > 0) {
$tPrecipFmt = sprintf("%01.2f",$tPrecip/100);
$usaprecip .= "<b>$tPrecipFmt$rUOM at $tStation, $tState</b>\n";
// Make results HTML pretty
$usahigh = str_replace("\n","<br/>\n",$usahigh);
$usalow = str_replace("\n","<br/>\n",$usalow);
$usaprecip = str_replace("\n","<br/>\n",$usaprecip);
print "<!-- usahigh ='$usahigh' -->\n";
print "<!-- usalow ='$usalow' -->\n";
print "<!-- usaprecip='$usaprecip' -->\n";
print '<!-- $filemtime = '.$filemtime.' $cache_age = '.$cache_age.' seconds.' . " -->\n";
print "<!-- Cache refresh rate = $cache_life seconds. Cache age = $cache_age seconds. -->\n";
