I'll be sure and let you know if i have the same USB issues. It seems that USB problems are pretty common with all the different manufacturers. Which suprises me..generally i find all my current USB connections much more stable that my serial RS-232 devices i had on my old PC's. I'm now using a Laptop and all i have is USB.
<snip>
JG
My company produces a USB driver for data collection (science education "probeware"
). They use a third party vendor for the driver "toolset" and then customize a set of library routines on top of it to do data collection. In general it is very reliable. Every once and while though we encounter an installation issue or a "long term collection" issue (installation issues are by far the most common). Most of the USB interfaces out there actually have to deal with relatively small amounts of data... keyboards, mice, joysticks don't really generate much data. But attach a motion detector or even a thermometer and the interface gets "hammered" of the course of either minutes or hours respectively.
I'm beginning to suspect that the USB connection is getting noise that causes the drop out and the Weather Display USB interface program (WMR100.exe?) just doesn't notice so it just keeps on sending the same cached data up to the program. The failures don't seem to follow a pattern -- sometimes I go for 17+ hours without incident and other times it fails within the first couple of minutes... and every interval in-between. It's a silent failure, the program goes along merrily posting the last data... over and over again.
It's like the weather station's heart beat just goes flat-line... beeeeeeeeeeepppp!
Now some USB interfaces tolerate plugin, plugout, plugin events very well; but, not so for this one... at least on my XP such a sequence yields "Unknown device". At this point, I'm left with no recourse than the reboot and restart.
