NOAA as part of its tropical satellite page also provides links to color sea surface temperature loops that show the last 15 days in HANIS for the Atlantic and the Pacific (central and eastern). Borrowing heavily from Jerry (gwwilk)have put together a page for this. You can see the page in action here:
SST Page.
I will follow the distribution mechanism for this script that Jerry has followed recently for the other HANIS scripts. Accordingly after clicking on these links, right-clicking and selecting 'Save as...' and then saving as the default file name (minus '.txt') will get you the following scripts:
wxus-sstloops-h5.php
Main Script - The Primary Script - Place this in your menu after selecting your default '$region' (see 'inc-show-region-h5-sst.php' for the correct codes) and putting it in the root of your site.
Dependent Script - The Dependent Script That Does the Work - Put this in the root of your site as well.
I put this together using Ken's wide format screen. Jerry is providing on his website a version for those of you using the narrow version of Ken's template. The scripts on Jerry's site can be found here:
Main Script for the main script in narrow format and here:
Dependent Script for the dependent script in narrow format. Thank you Jerry for the very usable base and the proof read.
Bob
