I have noticed that pouring the liquid water into the measuring tube results in a slightly lower measurement than the weighing method indicates.
For example, today the weighing method resulted in 15g which represents 0.07" of precipitation. It was all rain and not frozen, so I poured this into the inner cylinder. At first I got about 0.05"+. I scraped the sides of the outer cylinder with a plastic spoon which brought it to 0.06".
There were a number of droplets still in the gauge, despite my scraping. When I weighed the outer cylinder again, this "empty" gauge indicated 3g higher than the empty gauge number. This translates to 0.01". Adding this to the 0.06", I get a matching number of 0.07".
I sprayed my "third arm" funnel with the Plexus plastic spray, but I haven't sprayed the outer cylinders yet. I might do this to see if it reduces the amount of "Klingons".
Otherwise I think that I will start measuring the "empty" cylinder with Klingons and add that difference in as well. I was surprised at how much the residual drops added up to.
