So I have a website setup using Jachym's template. I modified the Meteobridge processing code (just one line) to process every 1 minute and record to the database at that interval instead of the default 5 minutes. For the original 5 minute updates, we were using this in the push services tab (with corresponding 5 min. interval set in MB):
meteobridge.php?t=[th0temp-avg5]&h=[th0hum-avg5]&p=[thb0seapress-avg5]&d=[th0dew-avg5]&w=[wind0wind-avg5]&g=[wind0wind-max5]&b=[wind0dir-avg5]&rr=[rain0rate-act]&r=[rain0total-sumday]&tmax=[th0temp-max5]&tmin=[th0temp-min5]&year=[YYYY]&month=[MM]&day=[DD]&hour=[hh]&minute=[mm]&seconds=[ss]
After changing the interval to 1 minute updates in the meteobridge.php processing code, I then went into Meteobridge and changed the push services entry to this:
meteobridge.php?t=[th0temp-avg1]&h=[th0hum-avg1]&p=[thb0seapress-avg1]&d=[th0dew-avg1]&w=[wind0wind-avg1]&g=[wind0wind-max1]&b=[wind0dir-avg1]&rr=[rain0rate-act]&r=[rain0total-sumday]&tmax=[th0temp-max1]&tmin=[th0temp-min1]&year=[YYYY]&month=[MM]&day=[DD]&hour=[hh]&minute=[mm]&seconds=[ss]
The issue I have been having since going to 1 minute updates is that at random times, the pressure value would be 0. Sometimes it does this every 30 min. or so, sometimes 1hr, 2hr, most has been 3hr without any issue. The data update does take place, and only the pressure value is an issue. Other values are recorded correctly. Anyone have ideas on what this might be or how to address it? Thanks.
