So, Bill, lets take it step by step
First lets try import of just one file - i.e. one daily log.
I created all the necessary scripts, it should be as easy as 123.
Assumption:
alldata table created, all template files uploaded, config.php properly set up (mysql)-
In your config.php also make sure that:
- parameters for units that start with "data" are set to the units used in the daily logs (the ones starting with "display" are used for the webpage, you can ignore those for now)
- limits for parameters are set properly
Then, upload the three files I attached and then, in your browser, simply open the WViewImport.html and follow the instructions.
The only thing that will change in the future - as I said, this is just importing one file, so upload some random daily log (ideally one that has some rain to check it works) and upload that file into the same directory as these scripts (the install directory). Then, for the path, use the "name.txt" of this log file.
The next step will then be specifying just a folder within the install directory, from which it will import all daily logs in bulk, but that will be the next step, first we have to make sure the imports work as such.
If you read the instructions on that page it will ask you to specify column numbers etc. I suggest you go through it and try the link as well, even though you in particular dont really need to set it up because I set the default values based on your file and so they correspond.
Last thing to do is enter your password, the on you specified in config.php (it is 12345 by default if you havent changed this).
Then click Import and.... and lets pray that when you then check your alldata table, the values should be there...
Let me know how it goes, it was relatively lot of changes I had to make, I modified the Cumulus import, but I had to make changes with regards to datetime formatting, the format of the file, automatic cumulative rain calculation etc, so it is possible it will not be working, but thats ok, I would fix this and Im sure we will eventually get it working.
EDIT:
SORRY THERE IS A MISTAKE IN THE FILES. IN THE WVIEW.PHP REPLACE THE "alldataTest" with "alldata" - THIS WAS JUST FOR TESTING PURPOSES AND I FORGOT TO CHANGE IT. IT IS THERE TWICE.
