Set the encoding to ANSI
You can turn on View, Show Symbols, Show End Of Line to make sure that only LF appears (not CRLF which will cause cron or bash to choke).
If you find both CR LF at the ends of the lines, there's an easy fix. Use Search, Replace
Find: \r\n
Replace: \n
select Extended Search mode, and replace all.
Best regards,
Ken
