....OK, take a snow fall of a 2" depth, by 1 sq. in. area. Melt it, how much precip. do you have? Now take a 2" depth by one sq. ft., melt it, how much precip. do you have now? If I shoveled two acres of a 2" snowfall in to a large enough vessel and melted it, I would have enough to put out a house fire.
I wish to know what is used as a standard for this chart, is it a 4" CoCoRaHS gauge? Sorry, I can't make it any planer than that....
Bill,
I think you are trying to over analyze here.
Think of it this way, your rain gauge is calibrated to read the same amount no matter what the size the funnel is. The size of funnel only effects the accuracy to some degree. That is the amount of water covering the ground if it were laying on top not being absorbed, no matter what the area is. The chart is estimating what the rain gage would read in the same manor, depth of water if the snow was melted, not volume of water over any specific area.
The larger size of the funnel is the equivalent of taking snow depth in multiple places. The final readings will be more accurate when averaged but the individual readings will be roughly the same. In simplest terms your just adding more data samples to refine or increase the accuracy of the end result.
