I'm sure this has something to do with permissions...but I thought I had them all.
The site I'm attempting to build is:
www.satxwx.com Here's what I have 777'd:
Data Folder (including wflash.txt & wflash2.txt)
Scripts Folder (including all 4 asp files & all 4 php files)
Config Folder (including Page1.txt, User.txt & Units.txt)
in the public_html file: Loader.swf, DataPod.swf, key.txt, site.txt and for good measure...weatherflash.htm
In VWS>Internet>WeatherFlash...I have the Server File Activate box checked...mapping to /public_html/Data
During set-up, I changed the 5th line of the site.txt file to PHP...Changed the names of the submit.php & .asp files (plus, made sure that my WF User ID was correctly inserted). I also uploaded the "new" key.txt file, so the Unauthorized User message no longer flashes in RED.
OK...Now that's done. I obviously had everything configured correctly "once", as I have a basic set-up on my WF page (
http://www.satxwx.com/weatherflash.htm). Now, however, when going in to make changes...they don't "stick" after clicking on LOCK.
Actually, things often "disappear" from my display -- I upload the key.txt file that came with the trial software (giving me the flashing Unregistered message in red), which seems to reset all of my gauges. I then upload my "paid" key.txt file and everything works well for a while (except for the main problem of not being able to edit the site).
Any thoughts on any of this? Anything you've got will be appreciated...this has been a real learning experience for a web-novice. I wish I had tried to get this thing up and running while the other forum was up...I understand there was a wealth of knowledge!
Matthew
San Antonio
www.satxwx.comJust found this message in my ftp error log (where UN represents my log-in name):
[Fri Oct 17 02:26:52 2008] [error] [client 205.188.117.8] File does not exist: /home/UN/public_html/Data/wflash.txt, referer:
http://satxwx.com/DataPod.swf
