I really like the 3D Sun Pie but it just didn't fit well in my older Alternate Dashboard.
After some nip & tucks, I ended up with a variation that did with a little less text. It gives me what I need in total daylight and an option to include the percent of daylight (show_pct). Like the MoonPhase graphic, a mouse-over will display info (changeinday)
The thing I mainly wanted was to display the beginning of the day slice (sunrise) in an accurate representation on a 24 hour circle that being with 6AM at the 9 o'clock and 6PM at the 3 o'clock positions on the disc. I wanted a High Noon graphic.
It didn't look too swift in 3D so 2D it was for me. It's a simple looking display but provides what I wanted.
Display snip is how it looks on
www.lascruces-weather.com (with its older version of the Alternate Dashboard)
<!-- *** BEGIN Total Daylight Hours *** -->
<td rowspan="3" valign="middle" align="center">
<?php
// Another version of the original Sun Pie script
// Uses a 2D Pie, less text and a mouse-over for $changeinday
// Make piechart
$testtime = substr($hoursofpossibledaylight,0,2);
$testminute = substr($hoursofpossibledaylight,3,2);
$testminute = $testminute/60;
$testresult = $testtime+$testminute;
$testljus = round(($testresult/24)*100,1);
$testmorker = 100-$testljus;
$time_arr = explode(':', $hoursofpossibledaylight, 2);
$suntime = (int)$time_arr[0] . " hrs " . (int)$time_arr[1] . " min";
$time_arr = explode(':', $changeinday);
if (substr($time_arr[0],0,1) != "-") { // -0 when getting shorter
// Only report seconds if less than 1 minute
if ((int)$time_arr[1]<1){
$sunchange = $time_arr[2] . " seconds more than yesterday";
} else {
$sunchange = (int)$time_arr[1] . " min " . $time_arr[2] . " seconds more than yesterday";
} else {
$sunchange = $time_arr[2] . " seconds less than yesterday";
} else {
$sunchange = (int)$time_arr[1] . " min " . $time_arr[2] . " seconds less than yesterday";
// ******************* High Noon *******************
$show_pct = '1'; // Add the daily percentage Daytime to 'Total Hours' display
if ($show_pct == '1'){
$show_suntime = $suntime . '~' . $testljus . "%";
}else{$show_suntime = $suntime;
$zulurads = 1.5708; // Google circle starts at 3 o'clock. Midnight would be at the 6 o'clock position
$rise_time = explode(':',$sunrise) ;
$rise_h = $rise_time[0];
$rise_m = explode(' ',$rise_time[1]);
$rise_minutes = ($rise_h*60)+$rise_m[0]; // Sunrise time in minutes past midnite
$sunrise_rads = deg2rad(.25*$rise_minutes)+$zulurads ;
// chp=$sunrise_rads in <img src= call to Google charts
// Better displayed with cht=p rather than the 3D call of cht=p3
// Change 'white' background with chf=bg,s,white&
// Change the '444444' to '000000' for pure black. All 6 numbers being the same (0 to F) grayscales 'Nite time'
// Edit the <img src= line to be one line. IT'S SPLIT ONLY FOR CLARITY
// Moved $sunchange info to 'title' for mouse hover
<table border="0" cellpadding="1" cellspacing="2">
<tr>
<td class="data1" style="text-align:center; border:none;">
<span style="font-weight:lighter; font-size:9px;">Total Daylight:</span>
</td>
</tr>
<tr>
<td class="data1" >
<img src="http://chart.apis.google.com/chart?chs=84x90&chma=0,0,0,0|0,0&chd=t:<?php echo $testljus;?>,<?php echo $testmorker;?>&cht=p&chp=<?php echo $sunrise_rads;?>&chf=bg,s,white&chtt=<?php echo $show_suntime;?>&chts=000000,9,c&chco=FFD700,444444" alt="Sun graph" title="<?php echo $sunchange;?>"></img>
<!-- This is only commented out to use in my older Alternate Dashboard
</td>
</tr>
</table>
</td>
<!-- *** END Total Daylight Hours *** -->
