All fixed, thanks to Brian (aka Windy)
Here is his feedback, hopefully this will help others.
1 - You need to untick the setting in the Daily Weather Report - User Input screen. This was the same problem as "stormwatch" on this wxforum
2 - Under control panel, solar sensor, you have the switch on there and you have ticked to set the icon from the solar data
you need to untick that and turn off the switch there, then wait for the next 1 minute update
3 - In the control panel, webfiles/webpage setup, real time ftp setup, tick, use the current weather from a metar
