Author Topic: Spring 2013 Cold Air Mass Movement Projections  (Read 19967 times)
Offline richard583
  • Paradise, CA
Re: Spring 2013 Cold Air Mass Movement Projections
« Reply #100 on: May 29, 2013, 08:37:05 PM »
With continuing to recede daily more northward over-all, beginning on the 31st of May or so main colder air looked at across the board within the main mid-latitudes, should start to move at a more stepped up pace more eastward through to the 7th or 8th of June.
Offline richard583
  • Paradise, CA
« Reply #101 on: June 04, 2013, 07:10:53 PM »
On the 8th of June or so, main colder air massif in places amounting to only more moderating "cooler air"should begin to move and spread daily more southward, through until just after the summer solstice.
This with its being caused to move increasingly more directly south from the 8th through the 17th of June or so, with its at the same time gradually more slowed movement and pace more eastward.
No "Numerical Wx-forecast Models" have been consulted, where considering the generation of the general outlook included above as part of this post.
Offline richard583
  • Paradise, CA
« Reply #102 on: June 06, 2013, 12:47:33 AM »
The heating trend has begun, as high pressure builds into our area. Main impacts for Wednesday and Thursday are hot temperatures in the Northern Sacramento Valley, a moderate Delta Breeze, and the possibility of thunderstorms over the Sierra crest. By Friday and Saturday, Northern California will be at the peak of this heat wave with widespread triple digit heat, near record levels. The hot and dry weather coupled with locally breezy North winds will bring fire weather concerns to the region. Temperatures are expected to return to near normal early next week.
Offline richard583
  • Paradise, CA
« Reply #103 on: June 07, 2013, 07:24:04 PM »
Hmm (?!). .. "Toasty".
(click for larger image.)
(source: Unisys Weather)
Offline richard583
  • Paradise, CA
« Reply #104 on: June 09, 2013, 09:22:03 PM »
Certainly working as such here in CA where I am, …
.. the initial 48 hours of "moderating" "cooler air" southward that I'd projected above, has resulted in a drop in main higher temps daily, of nearly 20°.
The greater shift in and of relatively more cold air more southward over the past two days (in fact more hemispheric), is shown fairly clearly where looking at the "gif-loop" accessible here just below covering much of N. Amer. and adjacent east and west.
(Click on this image, and allow time for this loop to load in.)
Offline richard583
  • Paradise, CA
« Reply #105 on: June 16, 2013, 03:05:55 PM »
With from the 19th through to the 23rd of June or so main colder air's being caused to move more quickly east, its further spread south through to the 21st or 22nd should be less directwith the main patterning of the Jet Stream shifting to increasingly more zonal.
Offline richard583
  • Paradise, CA
« Reply #106 on: June 18, 2013, 03:19:13 AM »
As I'd inferred that I would back on the 4th of this month, with continuing to move and spread still more southward daily, main and broader cold has at this point begun to move more strongly (Or at a less, slowed pace.) east.
Essentially more "zonally", and less "meridionally".
.. Again, broader cold's current main more general expansion south should continue through the 21st or 22nd.
No "Numerical Wx-forecast Models" have been consulted where considering the generation of the general outlook included above as part of this post.
Offline richard583
  • Paradise, CA
« Reply #107 on: June 20, 2013, 05:01:22 PM »
At this point, main colder air's stronger movement east has largely superseded its spread south.
My initial projection for the main summer season focusing on main "cooler" air broader movement from this point forward. http://www.wxforum.net/index.php?topic=19265.0#new
> Twitter posts
Offline richard583
  • Paradise, CA
« Reply #108 on: June 24, 2013, 05:26:06 AM »
All cooler and more moderating air should begin to retreat now at this point more. This, steadily more daily through to July 5th, when a next broader wave and delivery or relatively more cool air begins to move and spread south.
This, if with this more general scenario some cooler air's still making it more southward from now through the 29th with its slower movement east and where finding more conducive avenues to do so.
