Author Topic: WS-2080 Rain guage wind guard  (Read 5143 times)
Offline raedh
« on: April 17, 2012, 04:08:59 AM »
I was reading a notes on ws-2080 from http://lancet.mit.edu/~mwall/reviews/ws2080-amazon.html
and there is a note
the rain collector has no guard around its collection surface. if the collector is in a windy location, the readings will be low as most of the water will blow out of the collection dish. you might want to build a vertical wall around the collector to block the wind.
and wonder what is a verticall wall around the collector ?
does any other weather stations like davis not have this problem?
Offline DanS
  • Chiang Mai weather
    • ThaiWx
Re: WS-2080 Rain guage wind guard
« Reply #1 on: April 17, 2012, 04:55:19 AM »
That looks to be a "catch all" general statement for all rain gauges not just the 2080's. Sure, if you have any rain gauge out in the open and the wind is blowing across it you may miss some rain collection. Guess he meant a wind screen designed for rain gauges.
Offline raedh
« Reply #2 on: April 17, 2012, 09:55:58 AM »
does the wind screen for rain gauge an accessory can buy it with weather stations or we can make homemade one
Offline neondesert
    • http://www.neondesertweather.com
« Reply #3 on: April 17, 2012, 01:01:10 PM »
NovaLynx sells the Alter type shield pictured above 260-952 Alter-Type Rain Gauge Wind Screen
The page also lists the measurements and materials used in construction, so I don't see why you couldn't build one if you wanted to.
Here's another PDF that shows a great deal of detail that might be of help: http://www.allweatherinc.com/reference/sensors/6410_manual.pdf
Larry
"But it's a DRY Heat!"
Offline raedh
« Reply #4 on: April 17, 2012, 02:52:32 PM »
thanks neondesert very good pdf
