Hey Guys!
Again - thank you for your replies. I am glad to see that someone actually has noticed some things that I have written.
Lets take a barometric pressure sensor as an example for this discussion.
From
www.mouser.com, you can obtain a temperature compensated, absolute pressure sensor, manufactured by Freescale Semi (part number MPXM2102AS). This part, when interfaced with a MicroChip Corp 12-bit analog to digital converter (ADC) (part number TC7109CPL), provides me with barometric pressure, at 12bits of precision (13 if you count the sign bit).
I have finished the first stage of a design, which takes the ADC output and then displays the results as 3 hex digits. This design simply proves to me that I have the Sensor interfaced with the ADC correctly. As the atmospheric pressure changes, the digits change, thereby indicating that the ADC part of the design is converting a signal from the pressure sensor.
The second stage of the design will couple the ADC with a microprocessor. Dont laugh, but I have chosen to use an old Intel 8086 that a local hardware supplier has lying around in large quantities. I have already built a couple of projects using the 8086, so figuring out an interface with the ADC wont be impossible - timing maybe, but not the operation. ROM Burners are available for *cheap* on eBay now, and ROM chips are still fairly plentiful. Finding the software though (ie masm) for the 8086 has been a challenge, but again - entirely doable on the internet...
After I interface the ADC with the Microprocessor and am able to read intelligible results, I need to know how to calibrate the sensor. Specifically, I will already have an idea of how to calibrate the upper and lower bounds of the sensor (between 28 and 31 inches of Hg), but what standard do I use for calibration?
I found an old boy scout manual from the 1950's that shows how to build a home made mercury barometer, but the problem is that today, you can not just go down to the corner drug store and purchase a bucket full of mercury - people dont do that anymore. Too, I am not going to put my hand into a bucket filled with Mercury...
So, assuming that someone does not have access to a radio to listen to an AFIS broadcast at their local airport, how could someone calibrate this device? I cant build a Mercury barometer, and I dont have a radio tuned to airport radio frequencies...
THANK YOU for any ideas you might have...
