Weather Station Hardware => WiFiLogger/Meteo-Pi => Topic started by: Coolio on September 17, 2022, 11:06:36 AM
Hey guys,
I'm getting crazy, random data uploads to Wunderground. If you look at my readings on Wunderground, the updates bounce around all over the place. Does anyone know how to fix this? My goal is to get it back to normal Rapidfire every couple of seconds. Thanks!
https://www.wunderground.com/dashboard/pws/KCOEVERG80 (https://www.wunderground.com/dashboard/pws/KCOEVERG80)
Vantage Pro2 wireless
WifiLogger original
firmware 2.38
(https://i.ibb.co/x116Tcv/Screen-Shot-2022-09-17-at-8-50-53-AM.png) (https://ibb.co/5rrLHzD)
(https://i.ibb.co/89cMhyR/Screen-Shot-2022-09-17-at-8-51-39-AM.png) (https://ibb.co/NKSx40k)
(https://i.ibb.co/jhvhV2N/Screen-Shot-2022-09-17-at-8-52-22-AM.png) (https://ibb.co/rkGkbSj)
It is a WU problem, not something you can fix on your end. It has been happening to all of us for several days now. See the discussion here: https://www.wxforum.net/index.php?topic=44397.0
Please update firmware to the newest 2.41.
Please turn on to "GOOGLE + ROUTER"
Thank you. I thought it was just me. ](*,)
Will 2.41 work on WifiLogger 1? I'm on 2.38.
I couldn't find "Google+Router"
According to the WiFiLogger Website https://wifilogger.net/support.html, firmware 2.41 is only available for the WFL2. It shows 2.38 as the latest software for the WFL1. I also have a WFL2 which I just updated to 2.41. I checked the Stay Alive setting under the System on both the WFL1 and WFL2 and do not find a Google + Router setting on either. They both have the Google + Gateway default setting plus an Off setting and a Google setting. I cannot find a Google + Router setting on the WFL2 anywhere.
According to the website page listed above, the only change in 2.41 is “ Connecting to local AirLink and send data to the custom PHP server “. So 2.41 doesn’t add the Google + Router setting that WiFiLogger mentioned. I believe that he is in fact referring to the default setting of Google + gateway as your router is your gateway and he probably is using gateway and router interchangeably.
