Weather Station Hardware => Weather Web Cams => Topic started by: davidmc36 on April 27, 2021, 10:09:34 AM
I got this Reo RCL 410 and if I plug the power into barrel connector it works fine.
Does not come on with power applied to the POE Injector.
I read 12 volts on 4/5 7/8 of the RJ45.
I wonder if it is just the simplistic injector I have.
Should the best solution be to jusr get a switch with POE built In?
I am guessing the injector I have is not 802.3af compliant? Could that be the issue.?
That device uses either 12V DC from a power supply unit, PoE is usually not 12V its either 24v 48v or 54v
Oh I C.
That's another arena of tech I must get informed about.
Thanks for the tip
Awesome.
Next day delivery.
PoE Injector switch arrived.
Thanks for the tip.
What do you think about the camera, whats it like at night, does it show the clouds, stars etc? that's what I'm after and looking at the reo's at the minute, but obviously need one that can snapshot jpg, would prefer one that can stream live but i think i may have to use a program to serve the stream?
