Weather Station Hardware => Rainwise Weather Stations => Topic started by: DaleReid on June 05, 2020, 09:30:35 PM
With Rainwise no longer selling anything but the LR versions, I have a couple of stations that I'm trying to keep running if I can.
One was at a friend's place, and I thought that it was a battery/solar panel problem that was keeping data from being transmitted.
so far the battery is OK, On/Off switch works, and I trace voltage to several places on the board. I note that there is a switch, as shown in the photo, with two sliders. This is supposedly (and I think it is) a 433 MHz board, and therefore should not be able to select which one of four station IDs to associate with it, as you can the LR board.
It has a 'long' antenna, and the transmitter board at the bottom has three wires to it, a black, white and red that plug into the blue board, which is sparsely populated. It doesn't look at all like the ZeeBee board in another unit I have.
So is there a way to 'listen' to a frequency (I don't have a spectrum analyzer) to see if there is a 'buzz' or some other indication that a data packet were transmitted? If the ISS is working alright, I'd have to see if the receiver/display/Oracle is OK as the next step in trouble shooting.
Thanks for any help. Dale
