Weather Station Hardware => Barani Design Weather Stations and Accessories => Topic started by: mauro63 on June 02, 2020, 05:24:52 AM
I'm happy to inform that we have started the initial test phase of the new Barani Meteorain Compact 200 rain gauge, the first Barani rain gauge completely designed and realized by Barani
more information at this link
https://www.baranidesign.com/meteorain-iot-compact (https://www.baranidesign.com/meteorain-iot-compact)
The Meteorain tested in this phase is the cabled version, connected to a Meteohelix Pro, for the comparison will be used a Delta-ohm professional tipping bucket rain gauge and Davis Vantage pro rain gauge
Mauro
A good raining day today, not high rain-rate level but continuously from tonight with some lightning
Partial result:
Davis vp2 - 10,6 mm
Ecowitt wh40 - 11,0 mm
Meteorain Barani - 10,8 mm
Deltaohm - 10,8 mm
Mauro
I can communicate that the definitive version of Meteorain will be ready soon!
there was some improvements from his first release, tomorrow I think I will publish some images and, during the next weekend proceed to mount for field tests
Mauro
As I promised, some first images of the probably final version of MeteoRain Compact 200 ;)
[ You are not allowed to view attachments ] [ You are not allowed to view attachments ] [ You are not allowed to view attachments ] [ You are not allowed to view attachments ] [ You are not allowed to view attachments ]
Mauro
I know, I know....damn ugly :sad:
but damn functional ;)
Mauro
I've just ordered one. Could you explain to me how the cable from the MeteoHelix connects to the rain gauge?
Hi Daniel, the connection is very easy
the Meteohelix cable has two conductors, below the Meteorain cone you will find a couple of screws where you have to fix the cable, there's a hole on the Meteorain base to pass through the cable
Meteorain use a reed switch so is not important the polarity
that's all, but I'm at your disposal for any further information
If you don't know, is ready the bird spikes system for Meteorain ;)
Mauro
Do you know if the sigfox version will be able to connect to the MeteoHelix wireless. So all the data will be in one place rather having two stations set up on allmeteo
Of course ;)
With the new dashboard version, that I think will be ready in about two months, you will have all data on the same page
but, for clarity, the Meteorain will NOT send data to Meteohelix but directly to Sigfox, so you will have all data on the same page but with two different Sigfox subscription
this due to data limitations
Mauro
Hi. From what I'm aware of the meteorain IoT doesn't have rain rate is that correct?
not now, in the new firmware, that I think will be ready in a month or so, you will have rain rate ;)
Mauro
Another important info regarding IoT Meteorain version
Mauro
https://www.baranidesign.com/faq-articles/2020/8/10/-is-rain-intensity-compensation-built-into-meteorain-rain-gauges (https://www.baranidesign.com/faq-articles/2020/8/10/-is-rain-intensity-compensation-built-into-meteorain-rain-gauges)
Will it update automatically? Also I understand it will update every 10 mins is that correct? If so do you know what intervals the rain rate will be taken in?
the update is instantaneous, every single bucket event, and also the rain rate data, only the data transmission is every ten minutes, and you will have the maximum rain rate during the past ten minutes
Mauro
Thank you! Do you have any updates regarding them being shipped as there was a delay. I was told end of August is that the case still?
from my information, no particular delay, but send an email to them about this point ;)
Mauro
Hi have you got any news regarding the MeteoRain® 400?
Hi Daniel,
actually the company is very busy on the testing phase of the Meteorain Compact 200, that will be available soon in IoT version
I cannot give you now the probable date for Meteorain 400, but, in my opinion, the top version will have reduced preliminary stages, due to the fact that many components and solutions will be the same.
Mauro
Hi Daniel,
Mauro
HI Mauro are you testing both the meteorain IoT and the meteorain compact?
Hi Daniel,
Mauro
No Daniel,
I've not still received the new IoT version of Meteorain, but I think we are close
I've two Meteorain on test, one is connected to Meteohelix Pro, the other is connected to a digital pulse counter
Mauro
Hi Mauro have you got anymore updates regarding the Meteorain IoT. Looking at the Italian forum it seems to be reading a fair bit higher than the wired meteorain what's the reason behind this?
I think the problem may only be how tips are counted.
The rain gauges are exactly the same wired and sigfox / lora.
I have the sigfox version installed in my office and will soon be joined by a rain gauge from another brand.
If you look at the allMeteo portal to count the mm of rain, there may still be some problems.
I count the mm on my own and reset them at midnight.
http://www.kwos.org/roma_meteohelix/indexDesktop.php
Not having, at the moment, comparison rain gauges, I compare the data with a weather station not far away, and I don't notice particular problems.
At my home I have a MeteoRain Compact connected to the netatmo module which I compare with other rain gauges.
What do you mean by "connected to the netatmo module" ? netatmo doesn't allow off-brand devices to connect to anything they produce as far as I know..
What I mean is that the Netatmo rain gauge was not working, so I used the transmitter module to connect it to another rain gauge which is the MeteoRain Compact.
http://tiny.cc/kwos_raincompact (http://tiny.cc/kwos_raincompact)
Hi is Anyoune able to help me set up the wired meteorain. Does the wire completely go through p1?
No the wire has to be like this.
You need two wires. (https://uploads.tapatalk-cdn.com/20201127/3bd7cc7910db486c4beed97b548e2683.jpg)
Inviato dal mio Mi Note 10 utilizzando Tapatalk
Is that a black cable or cable tie?
As I've only got a white cable.it seems to be working now I think?
The cable you have, inside has two cables.
What you see white is only the outer sheath.
https://bambamsclub.wordpress.com/2013/08/08/setting-an-arduino-up-to-read-a-tipping-bucket-rain-gauge/amp/
Look the animated GIF.
Ah ok thanks I see now. It's dark now so I will do it tomorrow. Do both the cables inside go into the same hole p1?
One in P1 and one in P2.
remember to strip the wires. only the copper part must be screwed into P1 and P2
Look my image you see the metal part of the two wires.
Any idea why mine recorded rain with them both in p1? What does p2 do?
Hi I've got it all working now thanks for your help. Is it possible to send the rain data to wunderground?
Strangely, this seems limited to just 1 device, namely the MeteoHelix;
https://www.baranidesign.com/faq-articles/2020/2/3/forwarding-weather-station-data-to-weather-underground-wunderground
Another thing the barani devices really need: Binding of devices into one ID.
Ideally, we want to be able to use OpenWeather data, like, for example, one file upload containing;
BOF
$stationDate = "<!--stationDate-->";
$stationTime = "<!--stationTime-->";
$date = "<!--date-->";
$time = "<!--time-->";
$utcTime = "<!--utcTime-->";
$utcDate = "<!--utcDate-->";
$tempUnit = "<!--tempUnit-->";
$humUnit = "<!--humUnit-->";
$barUnit = "<!--barUnit-->";
$rainUnit = "<!--rainUnit-->";
$rateUnit = "<!--rateUnit-->";
$windUnit = "<!--windUnit-->";
$windDirection = "<!--windDirection-->";
$sunriseTime = "<!--sunriseTime-->";
$sunsetTime = "<!--sunsetTime-->";
$outsideTemp = "<!--outsideTemp-->";
$hiOutsideTemp = "<!--hiOutsideTemp-->";
$lowOutsideTemp = "<!--lowOutsideTemp-->";
$lowOutsideTempTime = "<!--lowOutsideTempTime-->";
$hiOutsideTempTime = "<!--hiOutsideTempTime-->";
$lowMonthlyOutsideTemp = "<!--lowMonthlyOutsideTemp-->";
$hiMonthlyOutsideTemp = "<!--hiMonthlyOutsideTemp-->";
$hiYearlyOutsideTemp = "<!--hiYearlyOutsideTemp-->";
$lowYearlyOutsideTemp = "<!--lowYearlyOutsideTemp-->";
$outsideHumidity = "<!--outsideHumidity-->";
$lowHumidity = "<!--lowHumidity-->";
$hiHumidity = "<!--hiHumidity-->";
$lowHumTime = "<!--lowHumTime-->";
$hiHumTime = "<!--hiHumTime-->";
$hiMonthlyHumidity = "<!--hiMonthlyHumidity-->";
$lowMonthlyHumidity = "<!--lowMonthlyHumidity-->";
$hiYearlyHumidity = "<!--hiYearlyHumidity-->";
$lowYearlyHumidity = "<!--lowYearlyHumidity-->";
$outsideDewPt = "<!--outsideDewPt-->";
$hiDewpoint = "<!--hiDewpoint-->";
$lowDewpoint = "<!--lowDewpoint-->";
$hiDewpointTime = "<!--hiDewpointTime-->";
$lowDewpointTime = "<!--lowDewpointTime-->";
$hiMonthlyDewpoint = "<!--hiMonthlyDewpoint-->";
$lowMonthlyDewpoint = "<!--lowMonthlyDewpoint-->";
$hiYearlyDewpoint = "<!--hiYearlyDewpoint-->";
$lowYearlyDewpoint = "<!--lowYearlyDewpoint-->";
$windSpeed = "<!--windSpeed-->";
$wind10Avg = "<!--wind10Avg-->";
$hiWindSpeed = "<!--hiWindSpeed-->";
$hiWindSpeedTime = "<!--hiWindSpeedTime-->";
$hiMonthlyWindSpeed = "<!--hiMonthlyWindSpeed-->";
$hiYearlyWindSpeed = "<!--hiYearlyWindSpeed-->";
$windDir = "<!--windDir-->";
$windChill = "<!--windChill-->";
$lowWindchill = "<!--lowWindchill-->";
$lowWindchillTime = "<!--lowWindchillTime-->";
$lowMonthlyWindchill = "<!--lowMonthlyWindchill-->";
$lowYearlyWindchill = "<!--lowYearlyWindchill-->";
$outsideHeatIndex = "<!--outsideHeatIndex-->";
$hiHeatindex = "<!--hiHeatindex-->";
$hiHeatindexTime = "<!--hiHeatindexTime-->";
$hiMonthlyHeatindex = "<!--hiMonthlyHeatindex-->";
$hiYearlyHeatindex = "<!--hiYearlyHeatindex-->";
$thw = "<!--thw-->";
$hiTHSWindex = "<!--hiTHSWindex-->";
$hiTHSWindexTime = "<!--hiTHSWindexTime-->";
$hiMonthlyTHSWindex = "<!--hiMonthlyTHSWindex-->";
$hiYearlyTHSWindex = "<!--hiYearlyTHSWindex-->";
$barometer = "<!--barometer-->";
$barTrend = "<!--barTrend-->";
$lowBarometer = "<!--lowBarometer-->";
$hiBarometer = "<!--hiBarometer-->";
$lowMonthlyBarometer = "<!--lowMonthlyBarometer-->";
$hiMonthlyBarometer = "<!--hiMonthlyBarometer-->";
$lowYearlyBarometer = "<!--lowYearlyBarometer-->";
$hiYearlyBarometer = "<!--hiYearlyBarometer-->";
$lowBarometerTime = "<!--lowBarometerTime-->";
$hiBarometerTime = "<!--hiBarometerTime-->";
$dailyRain = "<!--dailyRain-->";
$stormRain = "<!--stormRain-->";
$monthlyRain = "<!--monthlyRain-->";
$totalRain = "<!--totalRain-->";
$rainRate = "<!--rainRate-->";
$hiRainRate = "<!--hiRainRate-->";
$hiRainRateTime = "<!--hiRainRateTime-->";
$hiRainRateHour = "<!--hiRainRateHour-->";
$hiMonthlyRainRate = "<!--hiMonthlyRainRate-->";
$hiYearlyRainRate = "<!--hiYearlyRainRate-->";
$solarRad = "<!--solarRad-->";
$hiSolarRad = "<!--hiSolarRad-->";
$hiSolarRadTime = "<!--hiSolarRadTime-->";
$hiMonthlySolarRad = "<!--hiMonthlySolarRad-->";
$hiYearlySolarRad = "<!--hiYearlySolarRad-->";
$uv = "<!--uv-->";
$hiUV = "<!--hiUV-->";
$hiUVTime = "<!--hiUVTime-->";
$hiMonthlyUV = "<!--hiMonthlyUV-->";
$hiYearlyUV = "<!--hiYearlyUV-->";
$insideTemp = "<!--insideTemp-->";
$hiInsideTemp = "<!--hiInsideTemp-->";
$lowInsideTemp = "<!--lowInsideTemp-->";
$hiInsideTempTime = "<!--hiInsideTempTime-->";
$lowInsideTempTime = "<!--lowInsideTempTime-->";
$hiMonthlyInsideTemp = "<!--hiMonthlyInsideTemp-->";
$lowMonthlyInsideTemp = "<!--lowMonthlyInsideTemp-->";
$hiYearlyInsideTemp = "<!--hiYearlyInsideTemp-->";
$lowYearlyInsideTemp = "<!--lowYearlyInsideTemp-->";
$insideHumidity = "<!--insideHumidity-->";
$hiInsideHumidity = "<!--hiInsideHumidity-->";
$lowInsideHumidity = "<!--lowInsideHumidity-->";
$hiInsideHumidityTime = "<!--hiInsideHumidityTime-->";
$lowInsideHumidityTime = "<!--lowInsideHumidityTime-->";
$hiMonthlyInsideHumidity = "<!--hiMonthlyInsideHumidity-->";
$lowMonthlyInsideHumidity = "<!--lowMonthlyInsideHumidity-->";
$hiYearlyInsideHumidity = "<!--hiYearlyInsideHumidity-->";
$lowYearlyInsideHumidity = "<!--lowYearlyInsideHumidity-->";
$insideDewPt = "<!--insideDewPt-->";
$insideHeatIndex = "<!--insideHeatIndex-->";
$forecast = "<!--ForecastStr-->";
EOF
