Weather Station Hardware => Boltek/NexStorm Lightning Detectors => Topic started by: meteolarissa on March 17, 2019, 09:27:03 AM
Title: Interferences from washing machine
Post by: meteolarissa on March 17, 2019, 09:27:03 AM
Im owner of LD-250 lightning(9yrs) and last months i have interferences from my washing machine. I get 400-500strikes/min and more and sometimes nexstorm crashes and i need to open in again.
I used squelch at 15 but no difference. After 1,5 hour that w/machine finishes the programme all working properly again. Any suggestion /solution?
Vassilis
Larisa-Greece
https://ibb.co/xzSzGsH (https://ibb.co/xzSzGsH)
Title: Re: Interferences from washing machine
Post by: miraculon on March 17, 2019, 11:45:24 AM
I can make a few suggestions to try to isolate the problem.
Either the noise is what is called "conducted" and coming out on the power cables for the washing machine, or it is "radiated" and emanating from the motor.
What is the distance between the Boltek antenna and the washing machine?
Is the washing machine grounded? I see that Greece uses 230V 50Hz power. Are there only two power wires that supply the washing machine? (in the US we have a "neutral" and a "ground" (called Earth in UK). Is the washing machine housing completely surrounding the motor or is it exposed? What is the material of the housing, steel?
Does the motor have "brushes" and can you see small sparks if you can look inside the motor while it is running?
The only things I can think of at this time are:
Maybe some others have additional or better ideas.
Post by: meteolarissa on March 18, 2019, 04:50:42 AM
Unfortunately i have no idea about materials inside w/machine.
Antenna its about 8m away from w/machine. I will try put antenna to all corners on the terrace and hope i will be little lucky.
Today in the morning i just noticed that something happened in the morning from other source and not from w/machine. Nexstorm crashed again and i just opened it again.
Maybe its antenna problem after 9yrs of use or is detector. I don't know what to buy of these two  :grin:
omg
Vassilis
