Weather Software => Weather Display => Topic started by: tilde on March 28, 2008, 06:20:52 AM
Title: Clientraw.txt file on WDL application
Post by: tilde on March 28, 2008, 06:20:52 AM
Dear Sirs,
this is my first request over the wxforum.
I'm developping a software for a web server used with DAVIS PRO2 weather station. You can check a first sample at the address: http://meteosystem1.dyndns.org
With this units it's possible see the WDL program (on the above example I'm using a DAVIS PRO2 weather station) without using a computer. Actually the WDL inside the web server is the version 4.02; because of I'd like update it to vers 5.03 I need more information over the Clientraw.txt file.
Somebody know the Clientraw.txt file  structure ?  I need also the structure of other txt files that WDL can manage (clientrawdaily.txt, clientrawestra.txt ect..)
Please if somebody can help me, I'll be grateful.
Cheers
Title: Re: Clientraw.txt file on WDL application
Post by: saratogaWX on March 28, 2008, 09:31:28 AM
Hi, and welcome to the forum!
One of the best ways to see the current structure of the Weather-Display clientraw.txt (also clientrawhourly.txt, clientrawextra.txt and clientrawdaily.txt) is to use the WD Clientraw Parser at
http://www.tnetweather.com/wd-parser.php
Just point it to your website and it will decode/display the current contents (and structure) of the 4 files.
Best regards,
Ken
Post by: jmcmurry on March 28, 2008, 09:33:02 AM
In your WD folder you can find a file named clientrawdescription.txt that documents these files.  At http://www.tnetweather.com/wd-parser.php Kevin has a parser that will show you your current data and it also shows the structure.  Lastly, he's also kept up documentation of the files at http://www.tnetweather.com/nb-0100.php .  Hopefully these will all help you find what you need.
Good luck. - Jim
And Ken beat me to it but here it is anyway.
