Author Topic: Atlas reporting crazy high wind speeds  (Read 1057 times)
Offline gdicarlo
« on: March 24, 2024, 02:58:55 AM »
Over the past month, several times a week, my Atlas has been reporting wind speeds between 60 and 250 mph.Does anyone know what could be causing this, and how to fix it? Has anyone else out there had this problem before?
Offline Mirwin275
  • AcuRite Atlas (wind ext. & lightning detector)
Re: Atlas reporting crazy high wind speeds
« Reply #1 on: March 24, 2024, 03:44:05 PM »
First, check the batteries or replace them. You can also make sure the small plug that connects from the rain bucket trough to the main unit is fully secured and straight.
Offline gdicarlo
« Reply #2 on: March 24, 2024, 06:09:48 PM »
Replacing with new batteries did not help. The cable is tight and secure. The wind cups are seated securely on the base.
Offline DoctorKnow
« Reply #3 on: March 25, 2024, 03:36:08 PM »
Unscrew the wind section from the main body. Turn it to the right and lift. Check the cables where they connect. Put back and try.
Offline gdicarlo
« Reply #4 on: March 25, 2024, 06:55:55 PM »
Already tried that. Could it be that the anemometer has gone bad?
« Last Edit: March 25, 2024, 10:42:08 PM by gdicarlo »
Offline DoctorKnow
« Reply #5 on: March 26, 2024, 04:45:13 PM »
Could be, but I bet it's the cable. It may not be making a good connection inside the unit on the board.
Offline gdicarlo
« Reply #6 on: March 26, 2024, 05:02:12 PM »
Can that be easily fixed?
Offline DoctorKnow
« Reply #7 on: March 26, 2024, 05:49:04 PM »
Look for the atlas tear down pics on this forum. They will show you the insides of the housing where all the cables connect to the board. I wouldn't say it's easy, but it isn't impossible if you like to take things apart. Nincehelser I believe was the poster, and he isn't with us any longer...
