Author Topic: Getting false rain alert when it's sunny?  (Read 1240 times)
Offline Dennis Rogers
« on: March 04, 2016, 08:16:41 PM »
Seems when it's 27 degrees outside no dew or rain I had been getting false rain alerts.
Mind you have been playing around with adjusting the angle of my camera, so Is it that sensitive it's registering the moisture from my fingers setting off a false rain alert.
Offline SteveFitz1
    • Tyler Texas Weather
Re: Getting false rain alert when it's sunny?
« Reply #1 on: March 04, 2016, 08:31:49 PM »
I'm having the same issue. We haven't had any rain in the last week, yet it shows Rain 24 hours a day. Also, the UV index never goes below 1, even at night although I would expect it to be 0. I sent an email to their support several days ago asking about both issues, but I never received a response back.
Steve
« Reply #2 on: March 04, 2016, 08:35:20 PM »
Where do you see the UV in figures? It's listed ad ether low, medium, high, etc?
Online PaulMy
« Reply #3 on: March 04, 2016, 08:55:35 PM »
In your login portal, table view
Date   Time   Temperature   Humidity   UV   Pressure   Altitude   Voltage
03/03/2016   08:53PM   23.67°F   85%   1243 (lo)   1029mb   242.82m   2571mV
03/03/2016   08:59PM   23.63°F   85%   1243 (lo)   1029mb   242.82m   2571mV
03/03/2016   09:04PM   23.54°F   85%   1245 (lo)   1029mb   242.82m   2571mV
03/03/2016   09:09PM   23.49°F   85%   1245 (lo)   1030mb   242.82m   2570mV
« Reply #4 on: March 04, 2016, 09:30:11 PM »
The UV index is totally inaccurate same as barometric pressure as you cannot change it.
This station as yet is pretty rough.
The UV index compared to my Ambient station is far from accurate and never seems to get above low.
The temps, and humidity as well as the cam are the only things that work properly.
The UV is a waste of time. Even though I had sun on it for around 2 hours still said low.
Yesterday had it in consistent sun in the afternoon and was reading high.
So if it does not have consistent sun does not work to we'll.
My temps are within the other weather stations around me.
Offline waysta
« Reply #5 on: March 04, 2016, 10:10:16 PM »
I've seen erratic UV lo med hi on data portal, however the UV graphs on WU look like there is good data there.
The peaks are increasing every day as we head towards spring in NY.
There are some questions about how to handle the 1200 ish values when dark, but I think the data might be good.
